Problems with Cruise Control and Horn
Old Dec 2, 2002
Matt's Avatar
Matt is an unknown quantity at this point
I lowered my car with coilovers about 6 months ago and my cruise control and horn started to mess up alittle here and there. Now they do not work completely. Is this because i lowered it or is it a manufactor goof up please let me know by sending an email to lst_2001@yahoo.com, because i want to know if i should raise it back up or should i take it to the dealer because its under warrenty
Old Dec 2, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Just take it to the dealer...it should all be covered under warranty.
I doubt the lowering messed up the cruise or horn.
Old Dec 3, 2002
cim's Avatar
cim
cim is an unknown quantity at this point
Check brake lights for proper operation. If brake lights do not work when brake pedal is pressed then replace the fuse in the fuse/relay box under the hood (15A fuse). This should fix your problem with cruise control switches and horn. Else the problem is most likely a bad cable reel on the steering column.
Old Dec 3, 2002
Matt's Avatar
thanks for the help if anyone else knows evrything then please reply
Old Dec 3, 2002
solar's Avatar
solar is an unknown quantity at this point
Just because you lowered your car doesn't mean your whole warrenty is void. It sounds like you have a fuse or short in the system and I'd take it to the dealer ASAP, the only thing the dealer wouldn't repair under warrenty would be your suspention. Did you check the fuse like Cim said?
Old Dec 4, 2002
Matt's Avatar
ya i did but whats wierd at the beginning it worked off and on and then it wont work all of a sudden . now just yesterday myt light for my front air bags just came on. what the hell does that mean. does my car suck or is there just a major problem with it
Old Dec 4, 2002
solar's Avatar
You need to take it to the dealer ASAP! You might be having a ECU problem and from what your explaining it could get worse. Let us know what the dealer says.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
MamaBear2015
May 27, 2015 12:04 PM
cukaracha
May 16, 2015 02:11 PM
SSMatey
Apr 13, 2015 06:09 PM
Civic316
Electronics
Dec 10, 2001 12:03 PM
