what coulda caused this? plz help!!
Old Oct 13, 2002
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
sup guys
well, i was driving on da freeway the other day and as i was changing lanes, 3 lugnuts on my left rear wheel BROKE off (as in the thread that sticks out snapped in half). i got lucky cuz the last lug didn't come off and i was in the first lane the and exit was right there, so i pulled over. but i had no idea how that happened, so i just wanna hear some inputs about it and what you think the cause might be; therefore, i can prevent this from happening again.
so far i've come up with:
1) my custom sound system is too heavy (about 700lbs according to my installer)
2) my lugnuts were too tight? or loose?
i also just read that story about the guy that got 2 years for killing a 10 yr old with his wheel that came off...so yah...that kinda scared me
Old Oct 13, 2002
JohnnyLee's Avatar
7thgen guh chee
Do u have aftermarket rims??
Old Oct 13, 2002
speedracersong's Avatar
how did u know ur lug nuts broke off while u were driving?
knowing me i would probably just kept on driving until that 4th one came off and i spun out[IMG]i/expressions/laugh2.gif[/IMG]
Old Oct 13, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
your soundsystem is really heavy....our cars can only hold 950 total....
Old Oct 13, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
700 pounds!? that could have played a role in it. thats like a third of the cars own weight. also, someone could have loosened your lug nuts and thats why they flew off.
Old Oct 13, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
700 Pounds ???????????????????????????????????????????? GOOD GOD, THATS INSANE!!!! ya might wanna get fiberglass boxes instead of 1" thick sheet metal boxes???? and yes that could have happended from overtightening or being too lose.
Old Oct 13, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i'm not sure but i'm leaning toward the 700 lbs in your trunk. but then again, the lug nuts idea seems likely too [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 13, 2002
Snort2001's Avatar
Quote
[hr]Originally posted by: JohnnyLee
Do u have aftermarket rims??[hr]
yah, i have 17" rimz
Quote
[hr]Originally posted by: speedracersong
knowing me i would probably just kept on driving until that 4th one came off and i spun out[hr]
i knew it broke off cuz i heard a loud *** popping sound and smoke started to come out when the wheel rubbed against the fender cuz it came outta place..
Old Oct 13, 2002
RockfordFosgateBwoy's Avatar
RockfordFosgateBwoy is an unknown quantity at this point
whoa whoa whoa, 700 lbs, what is your enclosure made of? gold?
I find that extremely hard to beleive.....
About your situation, damn man, you got really lucky, the only thing that comes to mind is someone losened your lugs or something, because those thing dont come of easy, is axle bent or warped? i dont really know what could ahve happened, I've never heard of that happening...only on tractor-trailers
RF Bwoy
Old Oct 13, 2002
1955's Avatar
a civic wont move with that kind of weight my man!!! j/k but it sure as hell looks very low in the back,the lug nuts probably was absent in the first place,some one u know watch the movie"changing lane" u better look over your shoulder from now on,i am serious.
Old Oct 13, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Adding 700lbs of weight is the same as robbing your car of 70hp.
Old Oct 14, 2002
Snort2001's Avatar
haha, well, im all show, so speed doesn't matter that much to me
but i have 2 JL w7's, and they're 53lbs each already, plus 3 amps, the wood, battery, cap, dynamat, i'd say it's pretty close to 700lbs, not sure though
Old Oct 14, 2002
Snort2001's Avatar
oh yah, i forgot to mention that after i pulled over, i found the 3 lugs with the broken studs laying on the ground TOGETHER about 10 feet behind my car...that just seemed really really puzzling..[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 14, 2002
PESTLNC's Avatar
If they snapped off like that, I'd say the cause is definately weight.
Options:
1) Find some studs in a material stronger than steel (titanium?).
2) Drill out your hubs for larger studs and get wheels that will accomodate that.
3) Try and lose some weight in the trunk.
Old Oct 14, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
omg ...... 700 lbs ??? That poor Civic ...
Old Oct 15, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Quote
[hr]Originally posted by: Snort2001
but i have 2 JL w7's, and they're 53lbs each already, plus 3 amps, the wood, battery, cap, dynamat, i'd say it's pretty close to 700lbs, not sure though[hr]
I really doubt that ways 700 pounds??? lets see here
2 subs 100 pounds
3 amps - I'll guess high at 100 pounds for all 3
wood - a 4x8 piece of wood weighs 50 pounds tops and I doubt you used a whole piece
battery 50 pounds
cap maybe 2 pounds
dynamat? I doubt you use more than 100 pounds...
anyways that comes to maybe 400 pounds and that still seems high... either way I think you're full of it....
Old Oct 16, 2002
voltron622's Avatar
voltron622 is an unknown quantity at this point
Dayum...with all that weight, you'll need to make sure that your rear suspension is strong enough. The weight distribution of your system was probably imbalanced and made your car lean a certain way. Perhaps that rim was carrying most of the weight and snapped the lugs. Or..someone tried to jacked your rims and loosened the lugs.
tuvok
Aug 28, 2015 10:04 AM
GritzNGravy
Aug 19, 2015 03:03 AM
fecrni
Aug 8, 2015 06:15 PM
jzhartman
22
Jul 23, 2015 10:42 PM
jody501
Jul 10, 2015 11:01 AM
