hole in ac coil
Old Oct 8, 2002
beamer's Avatar
beamer is an unknown quantity at this point
hole in ac coil
yeah call me dumb. I was drilling a hole in the front where the H is and I struck the ac coil. It sprayed sh*t everywhere. Does anyone know where I can get a new one for cheap? Other than a junk yard.
Old Oct 9, 2002
solar's Avatar
solar is an unknown quantity at this point
The coil you're talking about is called the condenser. Don't ever use used A/C parts because you're just asking for trouble, the best way to find a cheaper new one, other than going to the dealer, is find a shop or parts store that deals in A/C parts and ask for a quote. Unless you know how to repair a A/C system you should take it to a shop. The reason is the following, you're going to need to evacuate (vacuum) the system, might have to replace the dryer (accumulator) and the correct amount of R-134a is very important. There is a small sticker right by your compressor and headlight that says how must r-134a is needed, I think its around 1.2lbs.
The reason why you don't want to use used A/C parts is because of contamination, if there is just a small speck of dirt or water in the part "it could" ruin the whole system. You might be able to save some money by installing the condenser yourself then take to a shop to check for leaks, evacauate and recharge the system. The reason why you might need a new Dryer is that its designed to remove moisture from the system, if more than a couple of drops of water enter the dryer its bad. What will happen is the desicant will become saturated and might break up and spread through out the system. Though this is possible I dought it will happen with your system. Let me know how you make out on fixing it.
Old Oct 9, 2002
beamer's Avatar
thats a good thing you said something b/c I was just going to get a used one. I have a plan then. I'm going to get a new one,put it in now, wait till spring so it looks dirty like the stock one and just take it to the dealer and play dumb. [IMG]i/expressions/beer_yum.gif[/IMG]warranty[IMG]i/expressions/beer_yum.gif[/IMG] what do you think?
Old Oct 9, 2002
solar's Avatar
Quote
[hr]Originally posted by: beamer
thats a good thing you said something b/c I was just going to get a used one. I have a plan then. I'm going to get a new one,put it in now, wait till spring so it looks dirty like the stock one and just take it to the dealer and play dumb. [IMG]i/expressions/beer_yum.gif[/IMG]warranty[IMG]i/expressions/beer_yum.gif[/IMG] what do you think?[hr]
LOL, well that might work I guess, the thing you need to make sure you do is buy a OEM Honda condenser. When you re-install the new condenser make sure the line fittings don't get all marked up. The dealer might smell a rat, also if they notice there is no R-134a at all in the system that might cause a red flag, normally a slight amount remains, unless there is a hugh leak which you won't have. I guess if you left one of the fitting loose on the condenser they would find that and think thats your leak. I think the Dealer might see through your little game there, but you never know.
I myself wouldn't do it, but I wasn't a Saint 13 years ago in college either.
Old Oct 9, 2002
orso's Avatar
orso is an unknown quantity at this point
use some jb weld to plug it up
Old Oct 9, 2002
solar's Avatar
Quote
[hr]Originally posted by: orso
use some jb weld to plug it up[hr]
It might work for a month but I really dought it, the system is under some very high pressures. Besides if the stuff gets into the system he could foul up other parts of the system. I repaired a system back in 1985 on a old beater car I had in College with JB Weld, it worked for about a week.
Old Oct 9, 2002
beamer's Avatar
I think that is a good idea about leaving the fitting loose. The main reason I think it will work is b/c it already went in for an a/c problem befor. They said there was a loose hose.
runawaykinms
15
Mar 22, 2019 10:32 AM
jdh022764
18
Nov 3, 2015 06:44 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
Islesfan
Sep 29, 2015 03:42 AM
jsmithe2010
Sep 25, 2015 07:42 PM
