radio static when the rear defroster is on
Old Sep 4, 2002
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
anyone have this happen to them. i got a new head unit but it was still doin it when i had the stock radio in the car. anyone know how i can fix this.
Old Sep 5, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Well, this could be a problem because our antennas are in the rear window.
Old Sep 5, 2002
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
is the antenna the wires that terminate on the middle of the rear window?
is the antenna connected to the defroster or use the defroster wires for an antenna?
if not, maybe the antenna is shorted over the defroster wires...
Old Sep 17, 2002
GyrlsWhip2's Avatar
GyrlsWhip2 is an unknown quantity at this point
I have the same damn problem and no matter what I do I cannot fix it. It only happens with my radio on not the cd player. It just started recently. If you find out what is wrong please let me know....it is driving me crazy.
Old Sep 17, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
same thing here, it sucks! and i'm getting sick of my CDs too!
Old Sep 17, 2002
01CivicEXs's Avatar
01CivicEXs is an unknown quantity at this point
believe it or not the rear defroster and the car's antenna pretty much run on the same line at one point.
If you crack open the right rear plastic panel (located between the small side window and the rear windshield) you will find the power antenna control box. There could be a loose/corroded connection in that area, or your power antenna wire on the wiring harness might not be connected.
This happened to me after I installed a new head unit, and i didnt realize that you had to connect the blue power antenna wire on the harness to the stock harness. Even though our cars have an integrated rear windshield antenna, it is still a power antenna, and that little box is an antenna booster.
If im not mistaken the antenna wire (in the car) is yellow with red stripes, and the defrost is yellow.
Ever since I connected the power antenna wire (blue) from the head unit harness to the car's power antenna (yellow red stripes), I havent had any more static. But I do recommend checking the little area around the box, as it could be the cause of something else. Hope this helps somewhat.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Kinneybrk
Jul 24, 2015 02:41 PM
Dave1984
Jul 22, 2015 06:10 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
