Converter bolt substitute
Old Jan 7, 2021
Cardinal fan's Avatar
Cardinal fan is an unknown quantity at this point
Question Converter bolt substitute
I have an 2003 EX SRS 1.7
Purchased Walker 54399 cat converter but it didn’t come with the converter bolts pressed into rear where flange attaches to b-pipe.
Honda gets $13 per bolt. Ouch! Are these necessary or can I purchase a high grade bolt and nut and be confident it will survive the heat and tough Midwest environment?
Also wondered if the rear flange on cat should have a groove machined into the flanges to accept the exhaust washer/ring? I haven’t yet disassembled pipe? Reference par numbers below.
Bolt, Converter - Honda (18176-P08-003)
Gasket, Pre Chamber (52.5MM-53.5MM) - Honda (18393-SH3-S00)
Cheers
Old Jan 7, 2021
Re: Converter bolt substitute
i would say both will rust.
not sure if there will be differences on when they will do so.
Old Jan 7, 2021
Colin42's Avatar
Just use normal bolts, grade 5 or better
Chato85
Mar 29, 2012 09:38 PM
mrfakerson
Oct 3, 2009 05:44 PM
g33s0n6656
May 15, 2004 12:13 AM
Shlomo
May 12, 2004 09:24 AM
SOHCVTEC
Jul 3, 2002 04:42 PM
