Where Do You Plug In the Smoke Machine to Check for Vacuum Leaks?
For a 2002 Honda Civic, I want to check for vacuum leaks.
Where would I plug in a smoke machine? Which hose do I disconnect?
Thanks.
Thanks.
Re: Where Do You Plug In the Smoke Machine to Check for Vacuum Leaks?
Usually hose to brake booster is first choice.
You dont actually have many vacuum lines and pretty much the ECU would pop a code if any of them was leaking.
To add to this is also helps to block off the throttle body intake during the smoke test. I usually use a ziploc (or other brand) plastic bag and painter's tape. I've only performed a smoke test on a 6th gen and not a 7th using a homemade smoke tester that works very well.
What symptoms cause you to want to do a smoke test?
PCV Air Leakage P1505.
I replaced both the PCV valve and the PCV Tube.
I also got P0505 Idle Speed Control System. (I removed the throttle body and IAC valve, cleaned them, and reinstalled them. I did the idle relearn procedure with no load. After a "choppy" start, the car's performance greatly improved. Idling at lights (with the A/C on since it's hot here in NYC and my car stereo) seems good. I'm guessing the computer is relearning my habits. For all this work, I also disconnected the battery to clean the terminals.
I just want to make sure there are no other vacuum leaks. Instead of buying or renting smoke machine, I may just try Scotty Kilmer's method of blowing cigar or pipe smoke into the tube and see where it comes out--if at all.
Thanks again.
Thanks again.
If you have a compressor it's easy to make a DIY smoker out of a paint can, rubber tubing (prefer corded), two 1/4" NPT step (x-mas tree) adapters, and a cigar.
pwnsauce
19
Apr 6, 2012 12:23 AM
kbook
Feb 16, 2011 01:30 PM
ramster
Engine Swaps
Mar 24, 2004 02:27 PM
