my car might have vacuum leaks/help identify hoses
Old Feb 15, 2011
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
Smile my car might have vacuum leaks/help identify hoses
Guys,
I stopped at the stop light. The light turn green, I released the break and pressed the gas and then it feel like the car is going to stall but not. I am not quite sure if it is caused by the vacuum leaks or not. But, I will to use the Carb/throttle Cleaner to test it.
But, which hoses are the vacuum lines. Is the one attached to the PCV also a vacuum line? or the ones on throttle body?
I have two pics from the part website here.
or
Thanks
Old Feb 16, 2011
boosted01civic's Avatar
boosted01civic will become famous soon enough
Re: my car might have vacuum leaks/help identify hoses
Why are you spraying carb cleaner into vacuum lines? Just pull intake tube off of the throttle body and spay a little bit in there if you are trying to clean the throttle body. Its not that expensive to replace vacuum lines and its pretty easy to do. Just replace them all and be sure you put the right hoses on there or at least make sure you clamp tehm down sufficiently.
bsmiley
Apr 27, 2015 01:27 PM
Braun
Apr 23, 2015 09:03 PM
mrohitredd
Apr 15, 2015 08:13 PM
blacklud
Apr 13, 2015 06:15 PM
deus-ex
Apr 13, 2015 12:29 PM
