Knocking when turning the wheel
Old Aug 8, 2018
Nacho90's Avatar
Nacho90 is an unknown quantity at this point
So I lowered my es1 and changed my outer tie rods and and I’m still getting a knocking when turning the steering wheel what could it be
Old Aug 8, 2018
Wankenstein's Avatar
Re: Knocking when turning the wheel
Installed them correctly? One time I purchased and installed a left (driver) and a right (passenger) outer tie rods. The parts had stamped on them "left" and "right". I installed them without first matching the angle/bends to old tie rods and afterwards got a knock on the drivers side. It turned out the driver's side outer tie rod was labelled/stamped incorrectly. I returned the part for the correct angle and it solved the issue.
Old Aug 8, 2018
Colin42's Avatar
Control arm bushings? Did you check to see what's loose before throwing parts at it?
Old Aug 8, 2018
Nacho90's Avatar
I’ll have to check that
Old Aug 8, 2018
Nacho90's Avatar
the outer tie rods where the only parts that seemed shot but I just changed them and still knocking
Old Aug 8, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Repetitive knocking when turning, like an axle makes?
Old Aug 9, 2018
GolNat's Avatar
Prelude Owner
So I lowered my es1
Could be the upper strut mount binding/slipping. I am assuming this is a noise that started after the lowering? Lowering springs? Are they indexed properly?
Jordan356
Jan 27, 2019 01:41 PM
03_EM2
Suspension
15
May 2, 2018 06:24 AM
Dckellyd
Apr 15, 2014 07:47 AM
SevenCyrus
Dec 16, 2006 11:58 AM
