2003 steering issue
Old Apr 14, 2014
Dckellyd's Avatar
Dckellyd is an unknown quantity at this point
2003 steering issue
When steering wheel is turned all the way to the left driver side putter tie rod end rubs the body. Only on driver side. It seems like its turning to far tie rod was bad on other side replaced it but the one on left seema good. Any ideas
Old Apr 14, 2014
GolNat's Avatar
Prelude Owner
Re: 2003 steering issue
Is your car at stock height? There shouldn't be anything in the way to cause it to rub on anything. Is it the power steering pump you are hearing?
Old Apr 14, 2014
Dckellyd's Avatar
Completely stock height. Everything is stock. I can actually see and here the tie rod end striking the body when I have someone else turn the wheel. I don't understand what would cause this if the tie rods are solid. I replaced the opposite side (passenger) it was bad. But this was doing this before that which is why I was checking the tie rods.
Old Apr 14, 2014
Something bent, something moved, something out of place in a big way.
Compare side to side.
Something should be obvious.
Think outside the bun.
Box. I mean box. Think outside the BOX.
Old Apr 15, 2014
Dckellyd's Avatar
I will have to check this out. I look under there and nothing i obviously bent or out of place. I am going to try and disassemble it a bit this weekend. so that hopefully perhaps I can get to the bottom of this. I would think that it should be an obvious problem ie controller arm bent or something of this nature. But I just don't see it. I have owned the car for a little over a year. It didn't do this at first. I haven't struck or hit anything with it So I don't get what it could be. Perhaps if I get a bit down and dirty with it I can get a better look.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
Bugman1400
May 15, 2015 08:10 PM
FlexEX
Jan 19, 2002 01:16 PM
