VTEC solenoid leak
Old Jul 13, 2018
Tdubs613's Avatar
Tdubs613 is an unknown quantity at this point
VTEC solenoid leak
Okay so beginning of June I was on my way back from Florida when my engine light came on. Waited till I got back home to have it check. Came up as code p2646 which is the vvt oil pressure switch was stuck in the off position. Since then I’ve had 2 and neither have fixed the problem. Went to a pull a parts got a whole new solenoid and now it leaks worse. On the inside there are theee numbers the original had 311 and other had 321. So I don’t know what to do next SOMEONE PLEASE HELP !!!!!
Old Jul 13, 2018
Colin42's Avatar
Re: VTEC solenoid leak
you know there are gaskets on the solenoid that leak and need to be replaced right?
Old Jul 13, 2018
Tdubs613's Avatar
I didn’t ! When I looked on YouTube it was them only replacing the whole thing. Okay so I know there is a top part and the bottom piece. Should I replace them both? It seems like it’s coming from the top because when the motor is running I see the oil.
Old Jul 13, 2018
Colin42's Avatar
These are the honda part numbers:
15825-P08-005
36172-P08-005
replace both for peace of mind
Mirquhl
15
Dec 20, 2018 06:03 AM
Tdubs613
Aug 7, 2018 11:01 AM
satinsilverem2
Mar 10, 2018 11:37 PM
skramer
Jan 8, 2018 06:10 PM
MC_d16
Feb 1, 2015 10:31 AM
