Weird Noises - Opinions? 2003 Manual (recordings)
Old Jul 13, 2018
kochab's Avatar
kochab is an unknown quantity at this point
Car: 2003 Honda Civic LX, Manual Transmission. 170k miles
Description of noises: metallic tumbling? Intermittent, somewhat random, mostly in lower gears as rpm changes
Is this a regular car sound or should I really have this checked?
Story: Car wouldn't pass smog this year, had to spend 2k to replace a cracked cat converter. After that, the car had sounds I didn't recognize, but I shrugged and said "This must be what a new cat sounds like" and I drove off.
An oil change later, the mechanic says "Don't you hear the weird sounds?" and I said, "That's totally the sounds it was making after YOU replaced the cat."
I moved, had another mechanic look at it, and replaced the alternator. Something about bearings tumbling around?? "No more sounds?" I asked this mechanic. "No more sounds," he assured. "Well, until you turn it on" he joked.
The sounds are 50% gone. I still hear them when shifting. Strangely, I hear them less when I shift early than when I shift normally. The higher the rpm, the more the sounds seem to occur.
Video 1: Sounds occur at about :23. Low speed, low gears, in a parking lot. I delayed shifting when the sound occurred to get a good recording. Probably in second gear.
Video 2: Sounds occur throughout the video, especially as I dip toward 60mph. Highway driving, 5th gear.
Appreciate any thoughts y'all have.
Old Jul 13, 2018
BrotatoChip's Avatar
Super Moderator
Re: Weird Noises - Opinions? 2003 Manual (recordings)
My first thought was it sounded like a heat shield rattling but it's kind of hard to tell in the video.
-Any idea where it's coming from? Front, back, left, right, underneath?
-Does it happen when revving the engine while not driving?
Old Jul 13, 2018
Slumpertcivic's Avatar
Be sure to whack on your resonator and muffler listening for rattles. Mine had a bunch of the crap from the converter blown into it. unbolted pipe and dumped the “black rock like” bits out and it was much more quite.
Old Jul 13, 2018
I can't hear squat.
You're trying to figure out some noise? WWSWD? (What Would Stevie Wonder Do?)
babzog
Jul 6, 2009 12:00 AM
KevKevBarkBark
Feb 23, 2009 11:52 PM
marcuse
Apr 6, 2007 11:38 PM
schnell8
Oct 1, 2005 05:50 PM
edl_37
Feb 27, 2005 01:13 PM
