Missing plug
Old May 27, 2018
Don_1's Avatar
Don_1 is an unknown quantity at this point
Missing plug
I recently dropped the transmission to replace the clutch on my 2004 lx. Everything is back up but I cant for the life of me figure out where this plug goes. Any ideas?
Last edited by Colin42; May 28, 2018 at 07:26 AM. Reason: Picture was between text
Old May 28, 2018
Colin42's Avatar
Re: Missing plug
speed sensor on the backside?
Old May 28, 2018
Don_1's Avatar
Re: Missing plug
I will have to check when I'm in front of the car later on. Will that cause the car to crank but not start?
Old May 28, 2018
Colin42's Avatar
Re: Missing plug
not sure, looks like you also have a ground disconnected in the picture, far right in picture
Old May 28, 2018
Don_1's Avatar
Re: Missing plug
That might be it. The right of the picture is the front of the car btw.
Old May 28, 2018
Don_1's Avatar
Re: Missing plug
Just to be clear. The ground goes on the bracket that the negative battery cable is attached to?
Old May 28, 2018
Colin42's Avatar
Re: Missing plug
That ground cable should go from the negative terminal to the car body right below the fuse box I believe
Old May 28, 2018
Re: Missing plug
You're also missing the breather vent cap. It came off that little tube sticking up by the shift linkage
Old May 28, 2018
Don_1's Avatar
Re: Missing plug
it was the speed sensor hidden underneath the shift cables. Thanks.
oney
Feb 1, 2010 05:40 PM
frejock
Nov 8, 2009 12:20 AM
anthrodoc
Jun 12, 2009 07:44 PM
aliangwb
Sep 4, 2007 02:54 PM
Pharoh
34
Feb 17, 2006 05:37 PM
