a plug is a plug is a....
Old Jun 9, 2009
anthrodoc's Avatar
anthrodoc is an unknown quantity at this point
My mechanic advises me to keep using the stock plugs in my 1997 Civic LX, but I want to switch to platinum or iridium. He says it might damage the engine to do that. Is that true?
Old Jun 9, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: a plug is a plug is a....
The only thing I can figure is if the plug ignites too hot and burns into the cylinder wall. Or if it changes the compression but that can be compensated for with higher/lower octane. No idea man, seems to have some validity but I wouldn't worry about it. He might be following warranty precautions.
Old Jun 9, 2009
he knows. stick with a good copper plug like NGK v-power. if you really have the extra money, go with denso iridium or ngk iridium IX. they will not hurt your engine, just take a small load off the electrical system because the iridium electrodes are smaller and require less energy to make the same spark. you wont see any extra hp tho. platinum plugs are terrible and the worst conductor (copper is best, iridium is pretty good). the only reason people use platinum is for longer life, on cars where it takes 4 hours to change the plugs.
Old Jun 9, 2009
back2black's Avatar
back2black is an unknown quantity at this point
When I was working as a GM mechanic, I loved people who bought into the "autozone tune-up" as I called it. Brand new Bosch Platinum plugs, and misfire codes out the wazoo..."BUt I just put new plugs in it"....yeah, you plugged the holes...but as far as spark plugs, well...
Run what the factory calls for, unless you are highly modded. Honda spent millions of dollars figuring out what plug would work best in your car...sure, that guy makin 7 bucks an hour at autozone prolly does know best
ROb
Old Jun 9, 2009
hey i used to work auto parts and i refused to sell people bosch plugs lol.
Old Jun 10, 2009
back2black's Avatar
Bosch plugs are good, don't get me wrong...if you have a German car that was designed to run Bosch plugs...and only then, the plugs that the manufacture calls for. ANd just a warning...never run those bosch platinum 4 plugs in a car that burns oil at all. Did that once. Couldn't figure out why the car got to running not so bueno after a couple of years...pulled the plugs. The area inside the 4 electrodes was completely filled with the carbony byproduct of an oil burner.
ROb
Old Jun 12, 2009
sql_civic's Avatar
You're the man, Rob.
Stick with OEM NGKs.
Old Jun 12, 2009
whitealexander's Avatar
whitealexander is an unknown quantity at this point
thanks for the info too mates..
SimpleUser
Apr 24, 2021 02:54 AM
mikey1
21
Aug 27, 2015 06:38 AM
Uan
Aug 23, 2015 03:03 AM
fecrni
Aug 8, 2015 06:15 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
