TDC - Normal for Valves to be Open?
Old May 22, 2018
0351jt's Avatar
0351jt is an unknown quantity at this point
Hi Everyone,
Thanks for your help on my last thread here.
https://www.civicforums.com/forums/3...se-bucket.html
I've pulled the head off, the gasket didn't look too bad but I guess some discoloration could indicate a leak.
My question was some of my valves on the head were open, does this look like bent valves or is it normal for some to be open? I did put the engine at TDC but it just slightly moved off while taking off the cam shaft.
I will be taking the head to a machine shop, I just want to know if its legit for them to quote a valve replacement. Which if the price is too high I'll look for a JDM D17A.
I read this thread here which does make it seem normal for some valves to be open at TDC (I didn't lay the head flat, as I read previously not to without understanding why not).
https://www.civicforums.com/forums/3...-question.html
Thanks again,
ID:	112234   Click image for larger version
ID:	112235   Click image for larger version
Old May 22, 2018
Re: TDC - Normal for Valves to be Open?
if you remove the camshaft and they still don't close, then they are bent, otherwise OK
Old May 22, 2018
Slumpertcivic's Avatar
The part that you can see on your valves looks pretty good in those pictures.
Still possible you have seating issues but doesn’t look like any of them melted.
Thats exactly why your not supposed to put the head down, always some valves will be open.
Old May 22, 2018
There are ALWAYS some valves open somewhere no matter where you position the camshaft.
@ #1 TDC will have #1 valves closed.
The rest of the valves for cyls 2, 3, 4, do not have to be closed at that position.
fleathatsme
Sep 13, 2013 06:35 PM
dezod
Engine Swaps
27
Dec 4, 2006 12:50 PM
sckew
Jun 5, 2006 06:40 PM
SODJAZERO
Jun 18, 2005 07:41 PM
SODJAZERO
Oct 13, 2004 09:48 PM
