04 EX auto suddenly running rough
Old May 22, 2018
SpeedReeeser516's Avatar
SpeedReeeser516 is an unknown quantity at this point
I have read the threads I can find that semi relates which are mostly rough idle threads. On my way to work this morning I get to a stop light and the car does start idling very rough, so rough that lights are dimming and it feels like it's going to die. Had to press the pedal harder than normal to get going, it felt like one cylinder wasn't firing until 45 or so then it seemed to clear up. Go on the interstate, felt a little rough again for a few minutes then seemed to clear up and run fine, still held speed no problem using cc and would get back up to speed the same as usual on steeper inclines. Once off the highway the problem came back and even got a little worse from stop light to stop light. The CEL did come one and now it does idle very low but doesn't die. I shut the vehicle off and restarted the idle was still low but the CEL was no longer flashing. My first thought was plugs, wires (just read this car doesn't have wires), and dist cap. I wanted to see what others thought based on the description. Also want to add that since I bought the car a few months ago it has always seemed to have a very slight miss when setting at a stop light, and it wasn't constant or at every stop. During longer stops you could feel it, it was so little and infrequent that I didn't really worry about it, and again my first thought was the car probably needed a tune up. I will stop by an auto store after work to check codes.
Old May 22, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 04 EX auto suddenly running rough
If this vehicle is new to you then you should be doing some maintenance with the assumption that little to none was done.
Such as for starters: oil change, spark plugs (use NGK OEM ones only), clean throttle body and IACV, change air filter, flush brake fluid, drain and fill (no flushing!) with Honda ATF DW-1, timing belt and water pump needed at 105,000 miles or every 7 yrs whichever first.
Check that the alternator bracket bolts are secure - common issue.
Check for a CEL code and report back in format P####.
No distributor on this engine BTW.
Old May 22, 2018
Thanks, I should have mentioned I do have the CarFax that shows all mentioned PM done per schedule. I also just had the alt bracket replaced a couple weeks ago. the only thing I am not sure has been done are the spark plugs, and the clean throttle body/IACV since some of the carfax entires just say maint performed. I will check codes and post back. No wires or dist. damn I'm getting old.
Old May 22, 2018
Slumpertcivic's Avatar
Flashing light usually is the computer senses a misfire condition aka one or more cylinders is not going bang correctly.
Definately need to get the codes read, your local auto parts store, or buy a code reader preferably one with live data.
Hopefully it’s just a flaky coil pack based on code, before just replacing them, swap the one that reported as issue with another, reset the codes, and take it for another drive till code comes back then read code again.
If the code code moved to the cylinder you swapped the coil too then a simple replace should fix you up. If the code stays on the same cylinder you will want that live data feature to keep from just shooting parts at it randomly.
Old May 22, 2018
I did think it was odd the the CEL was flashing, since I've never had a CEL in this car I thought maybe that was the norm (I know read the owners manual ) I will get the codes read and as follow your instructions, here's hoping it's just a coil and I don't need a live data feed. At least my old school thinking of plugs, wires, cap, may have been at least looking in the right direction. Thanks for the reply.
Old May 22, 2018
When the light is flashing, it’s telling you not only is there a problem, but it’s bad enough you can damage the engine / catalytic converter / catch fire if driven....
Old May 22, 2018
More good to know info, hope I make it to autozone and home with no issue. CEL light didn't start flashing until I pushed the pedal almost to the floor leaving a light, guess I won't be doing that again.
Old May 22, 2018
P0303 No. 3 Cylinder Misfire Headed now to swap the coil from No 3 with another cylinder, reset the code and see if the problem follows the coil.
Old May 22, 2018
Moved from 3 to 2 with the coil, replaced coil no more misfire. Thanks again for the info and help!
riceburner254
May 9, 2013 01:08 PM
bruiny
Apr 23, 2013 07:20 PM
bradmanuwf
Engine Swaps
39
Jan 9, 2005 12:34 PM
abmerop18
Engine Swaps
Dec 23, 2004 10:33 AM
conspiracy90
May 22, 2002 02:18 PM
