2002 honda civic running issue
2002 honda civic lx 4 cylinder. The car has been setti g for about a year and half. The car will start and idle but is not smooth and when accelerate it boggs out fuel pressure is good. It throws no codes. New plugs and doesnt appear to have any wires chewed up. 170000 miles on car. Any help would appreciated
Re: 2002 honda civic running issue
Drain out old gasoline
Refill with fresh gasoline
Why was it sitting for so long, what problem did it have that nobody wanted to fix?
the transmission went out got a new trany and no we have this issue daughters car was waiting on funds to fix transmission. Car ran great prior to parking
disconnect battery, wait 15-20 mins, reconnect battery and start car, making sure all electrical loads are off (lights, blower, radio, etc), let car run for around 20 mins or until the fans come on and off twice
[QUOTE=Colin42;4740251]disconnect battery, wait 15-20 mins, reconnect battery and start car, making sure all electrical loads are off (lights, blower, radio, etc), let car run for around 20 mins or until the fans come on
thanks i will try that.
One dead cylinder miss?
Cylinder contribution check to identify if one is "dead" and not firing...
Then check ignition, spark, compression, etc....
Possible stuck fuel injector? (tap on injectors while it's running, maybe you can jar a stuck one into working again)
ASchwagman
Engine start problems
Oct 22, 2018 11:22 AM
Randy L Dotson
Jan 1, 2016 12:18 PM
RRSRER
Oct 28, 2011 11:51 PM
