Weirdest Issue Ever
Old Sep 1, 2016
jsmith12's Avatar
jsmith12 is an unknown quantity at this point
Weirdest Issue Ever
The car is a 2004 Honda Civic Ex 1.7
The car keeps dying, no power, cuts out, won't go pass 3500 rpms, check engine and emission lights are on...
What I have done is replaced battery and alternator and throttle position sensor
Overnight I'll put a battery charger on car and let it charge all night. When I start it up no emission light is one and car runs perfect. Then when I hit the first Stoplight the car instantly dies and looses all power and won't go pass 3500 rpms.
I've heard a Crankshaft Position Sensor could be the issue... But would that cause the battery to loose juice?
Old Sep 1, 2016
Re: Weirdest Issue Ever
And the fault codes are.....?
Old Sep 1, 2016
jsmith12's Avatar
P0336 BUT when I had Autozone run there computer I told them it was a DX instead of a Ex... Probably have them run test again later today when I get off work.
Old Sep 1, 2016
Originally Posted by jsmith12
P0336
So fix the code.
That doesn't matter.
Old Sep 1, 2016
jsmith12's Avatar
But wouldn't a bad CKP essentially prevent the car from even starting? I know of people that had bad CKP and the car wouldn't even start.... In my case the car does start up.
Old Sep 1, 2016
What makes you think the P0336 code is about CKP?
Research it.
paul.f
Nov 6, 2015 10:41 AM
garigola
Oct 29, 2015 01:01 PM
JackImpact
Suspension
Oct 28, 2015 10:44 PM
trv020
Oct 28, 2015 10:37 PM
johnmcm7
Oct 27, 2015 09:30 PM
