need to check out, What you see you wont believe....
Old Aug 31, 2016
mnelson696's Avatar
mnelson696 is an unknown quantity at this point
Guys my 2003 civic ex vtech has 100k miles brand new timing belt headgasket new every part on car, seriously. Just put new engine in it, when i drive it sometimes rarely makes an extreme rattling sound from somewhere for like 5 seconds then goes away it sounds like one of the tires is shaking like insane, however they do get low sometimes but i dont think when this happens.. other than that it runs perfectly. the tires were all brand new however the car sat along time after blowing motor n back 2 tires go flat every couple days. could this be a tire or alignment issue, im stumped? i want to fix n im mechanically inclined however idk where to start for this one. Thank you so much guys, i know im new here, i owe you guys everything i will answer as many of other peoples questions as i can to pay it back. thanks guys.
Last edited by mnelson696; Aug 31, 2016 at 03:26 AM. Reason: explain better - thanks everyone :)
Old Aug 31, 2016
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
Re: need to check out, What you see you wont believe....
It would help us best diagnose the issue if you could determine the relative location or exact area from where the sound is coming. You mention a new engine but think the rattling may be coming from the rear tires. Is the sound coming from the rear for sure? does it do this at a certain speed or any speed?
Old Aug 31, 2016
mnelson696's Avatar
i notice it at like average speeds like 50mph. it just shakes bad for like3 seconds and stops . and happens every now and then.
Old Aug 31, 2016
it's a rattling sound or a shake? confused still
Old Sep 1, 2016
mnelson696's Avatar
picture hitting like 10 speed bumps in a row at full speed.
Old Sep 1, 2016
Colin42's Avatar
check that all your bushings and bolts are tight
Old Sep 1, 2016
mnelson696's Avatar
i noticed a tire balance weight in my driveway that fell off . could that cause it as well?
Old Sep 1, 2016
Colin42's Avatar
having unbalanced tires certainly isn't going to help, having the car sit not moving on flat tires for a long time isn't going to help either.
start checking for loose/broken suspension things,
might want to get the balance on the wheels checked as well
Old Sep 2, 2016
mnelson696's Avatar
thanks everyone went to town fair tire today and they balanced the tire that had the weight fall off and rotated the tires . hopefully that did it.
Old Sep 21, 2016
5.0Thunder's Avatar
I can't imagine that would only cause problems at a certain speed range but was it fixed?
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
41
Nov 11, 2015 09:15 AM
Hani4g
Oct 31, 2015 02:09 PM
98hondaciviclx
Oct 30, 2015 12:21 AM
sshoi
Exterior
Oct 29, 2015 11:09 AM
