Passenger power window not working
2001 Honda Civic - Passenger power window is not working, I checked the fuse 22 and it was bad. I replaced the fuse and turned ignition and immediately it blew . Tried again put a new 20 fuse on and the second I turn the key the fuse blows.
Anyone know what I should do next?
Re: Passenger power window not working
Figure out why the fuse is blowing.
Fuse 22 supplies power to both the master switch in the drivers door AND the window switch in the passengers door.
Unplug each switch one at a time and see if the fuse still blows after disconnecting each switch?
I'd kinda expect wiring issues in a door jamb harness.
Well I only had one fuse left but I unplugged the passenger door switch and it still blew. I think it is wiring but I don't even know where to start looking. The passenger door wiring is all taped up good and not touching anything.
Thanks
Thanks
If the passenger side wiring harness tests OK, then there may be a short elsewhere. If you don't already have wiring diagrams, I've found the Haynes manual useful. There's a whole chapter in the back with wiring for (almost) every system in the car.
93IndyCivicGuy
Feb 28, 2017 09:14 PM
NathanKeller
Jan 22, 2016 07:12 AM
mercerguy323
Nov 26, 2015 07:24 PM
