Key won't turn (ignition switch)
Old Dec 13, 2015
FxckWil's Avatar
FxckWil is an unknown quantity at this point
So I changed my ignition switch today but once I finished my key wouldn't turn at all. Does anyone know what I might've done wrong?
Old Dec 13, 2015
Re: Key won't turn (ignition switch)
You turned the steering wheel until it locked? Now there's pressure against the lock and you can't turn the key until you remove the pressure.....by turning the wheel.
Did you check that everything actually worked before assembling?
Or you screwed something up. Take it apart and recheck whatever you did.
Old Dec 13, 2015
FxckWil's Avatar
I got it figured out, I didn't have the key on the off position when putting the switch on. Thanks for your help!
spitball
Dec 13, 2015 07:46 AM
zer0410
Dec 11, 2015 12:31 PM
kingrat
Dec 9, 2015 05:34 PM
harveyj98
Nov 30, 2015 07:44 PM
Buttertopwhite
Nov 17, 2015 06:41 PM
