LED turning signal
Old Dec 11, 2015
zer0410's Avatar
zer0410 is an unknown quantity at this point
LED turning signal
I want to get switch back turning signals for my 03 civic. Something like this,
http://www.amazon.com/JDM-ASTAR-Extremely-Chipsets-Switchback/dp/B00RV4BOGM/ref=cm_cr_pr_product_top?ie=UTF8 http://www.amazon.com/JDM-ASTAR-Extremely-Chipsets-Switchback/dp/B00RV4BOGM/ref=cm_cr_pr_product_top?ie=UTF8
They're supposedly 2.32 inches long, you think they will fit into the turning signal housing of the headlight? Also, should I get load resistors or an electronic flasher relay?
Old Dec 11, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: LED turning signal
Originally Posted by zer0410
= Also, should I get load resistors or an electronic flasher relay?
I would use the solid state flasher. The biggest drawback to them is that when a turn signal bulb burns out they don't change their flash speed. They also don't care about proper bulb wattages so it will always flash at the correct speed.
If you don't choose the proper load resistor you will have quick/slow turn signal blinking.
I don't know if the units you are looking at will fit or not, but honda generally leaves room for bulbs. Since leds don't generate much heat they can get much closer to the lens without causing any issues. Make sure they don't just look cool, make sure they are very visible to signal your driving intentions to other drivers.
Old Dec 11, 2015
What sorcery is this?
sidelines321
Nov 30, 2015 08:02 PM
krutch52
Nov 27, 2015 06:32 PM
Fearthebeard
Nov 23, 2015 11:44 PM
SlowVtek
Nov 20, 2015 12:56 PM
Youngrob650
Nov 12, 2015 11:01 PM
