timing belt and water pump
Old May 2, 2016
Tush's Avatar
Tush is an unknown quantity at this point
Hey everyone ... newbie here. Well, not to cars but to this forum.
I just inheritted an '04 with only 30k miles
I find the engine doesn't sound like a Honda to me. I have had quite a few and this one sounds a little more 'loose'. Just wondering what you think about the belt with respect to its age not miles.
Old May 2, 2016
Tush's Avatar
Re: Does the 7th Gen Civic have an interference Engine?
Secondly ... I've heard that if I'm having the timing belt changed that it would be a good idea to have the water pump changed at the same time (save on labour later).
What do you think?
Old May 2, 2016
Re: timing belt and water pump
you revived an 8 years old thread and your question was not related to the original thread, so moved to a new thread.
Old May 2, 2016
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
I personally think the belt age is certainly a factor. At 11 yrs, I would plan to do it soon. Check the valve clearances? Maybe they need adjusting.
I would drain & fill the tranny for sure, but congrats on a really low mileage 7th gen!
Old May 2, 2016
AP4114's Avatar
AP4114 is an unknown quantity at this point
Last year got 2004 lx with 56k now have 64k doing trainy drain and fill twice and oil change then belts. Changing timing belt because of age.
I am not a mechanic who would i bring it to have the valves checked and how much is a reasonable price to have them adjusted and should this be done before or after timing belt replacement? Also should i replace water pump too because of age?
Old May 2, 2016
For both of the cars with super low miles, I'd probably just inspect the pump for leakage from the weep hole (seal leakage) and around the flat areas (gasket leakage) while it's apart, then decide.
It's time to replace the coolant at 10 years too, and I'd use only Hondas blue type-2 premixed.
IMO water pump problems dropped significantly in the years since since they switched to this as the factory fill coolant, so I think it's good stuff.
At the shop we don't automatically stuff water pumps in with every timing belt job anymore.
Old May 2, 2016
bsmiley's Avatar
I recently posted about my timing belt change and I'm not a professional mechanic.
I've had my Civic for two years and I've done quite a bit to it. Most with the help of this forum.
You have to start somewhere. See if you have a friend who could give you a hand. It can be fun to work together with someone.
When you change the TB you have to take off the valve cover and its a good time to replace the gasket if it is leaking or seeping oil. Get some permatex or Hondabond and a new gasket. I would change the alternator belt and power steering belt while you have them off to change the TB. I would also adjust the valve clearances at the same time.
You can buy some parts (like Denso or NTK parts) from Amazon or Rockauto, but do not buy cheap stuff off Ebay....
Majestic Honda will sell you the real deal Honda parts to change your timing belt, tensioner and water pump. Their website is: http://www.hondaautomotiveparts.com/...artsSearch.jsp
I just emailed them my VIN and asked them to put together a quote for everything I'd need to change my timing belt. (Panya Manivong is who emailed me back. pmanivong@majestichonda.com)
Does your car sound okay? The OP said his engine doesn't sound like a Honda (I'm not sure what that means, I can't hear his engine). Here is a youtube video that shows how to adjust your valve clearances.
I believe there is a DIY here on the forum, search for it.
You can download the Civic repair manual from my link here: https://www.civicforums.com/forums/1...e-updated.html
Old May 3, 2016
Tush's Avatar
Thanks for all the info guys ... much appreciated.
Old May 3, 2016
You should probably figure out if this is normal or not before you dive into the timing belt job. Compare to an identical car
t.ralsty
Jul 2, 2016 10:24 PM
83rs50
Jan 14, 2016 12:38 PM
simons81
Nov 4, 2015 07:48 PM
98hondaciviclx
Oct 30, 2015 12:21 AM
Tedverseti
Oct 22, 2015 01:09 PM
