Nylock headache
Old Feb 25, 2016
Steven Eisler's Avatar
Steven Eisler is an unknown quantity at this point
Nylock headache
Attempting to replace the o-ring in the leaking plug on the cylinder head next to EGR Valve. While attempting to remove the EGR valve, I noticed one of the two 8mm nuts is nylon. One turn of my ratchet and it was already stripped. I've been beating the hell out of that nut to get it off of there to no avail thus far. Any suggestions? Heating it up? Any solvents?
Cheers
Old Feb 25, 2016
Wankenstein's Avatar
Re: Nylock headache
Cheers
Obviously not a factory nut and should be two metal ones. Please post pics. Did you try simultaneously prying under the nut with a flat head scredriver while turning the nut counter-clockwise to remove. Alternatively you could lift up on the EGR valve while trying to turning the nut to remove. Another option is to cut it off with a drimmel, box-cutter or whatever else may work within that space.
Old Feb 25, 2016
emich's Avatar
emich is an unknown quantity at this point
Re: Nylock headache
They should be 12 mm regular nuts.
Old Feb 25, 2016
Re: Nylock headache
Nylon nut (all plastic) or nylock locking nut?
Worst case might be removing the whole cast piece from the end of the head and carry it to the vise on the work bench so it's easier to deal with.
Old Feb 25, 2016
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Re: Nylock headache
When I took my EGR valve off, the studs actually come off and the nuts stayed on! I had to get the nuts off the studs after I took the valve out.
So the EGR valve bolts are actually threaded studs into the cast. You should be able, if the nut is affixed on there well enough, to thread the stud out of the cast and just get a new stud from Honda.
Not sure if all Civics are like this, but probably?
btungcab87
19
Feb 20, 2016 12:31 PM
Michael Irby
Dec 23, 2015 07:30 PM
FxckWil
Dec 21, 2015 10:25 AM
Wesley02Si
Exterior
Dec 16, 2015 07:07 PM
two_civic_guy
Dec 4, 2015 09:47 PM
