cylinder head replacement
Re: cylinder head replacement
I thought your engine was overheated. Is it warped beyond repair?
Now you've got bent valves too?
If you got a head elsewhere, you can leak check the valves on the workbench using liquid, and you can have it checked for flatness at a machine shop..... or many (certainly not all) mechanics have their own precision straightedge just for checking this kind of work. I know I do.
If it measures flat and in spec there's no point in resurfacing.
I dropped the head off at the machine shop Friday.He calls me today saying the valves are bent and leaking real bad.He asked if the timing belt broke.It didn't break and no teeth are missing. The head is warped but it will cost me five hundred and eighty dollars with parts and labor.
Ouch.
Was it still correctly timed when you took it apart?
Did you rotate cam or crank after removing the timing belt?
I found a site www.cylinderheads.com, you can get a cylinder rebuilt for about 300.
amrhamed
Aug 7, 2015 11:39 AM
qlitten
Jul 21, 2015 03:12 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
JUNITO
Jul 9, 2015 08:36 PM
