Weird Noise Like a Remote Control Car
Old 07-23-2015
BootyDo's Avatar
BootyDo is an unknown quantity at this point
Question Weird Noise Like a Remote Control Car
Hi All,
My gf's car is suddenly making a weird noise like someone is driving a RC car under her hood. The sounds seems to be coming from the right side of the engine, (as you're staring at the car; driver's side of the engine). The sound is s bit louder as she turns and once in higher revs, almost seems to go away. Though that could also just be the case of the engine drowning out the sound.
From some stuff I was searching online, it sounds like it could be related to the power steering pump. Fluid looks okay though.
Any thoughts on this? FWIW, the car is an EX with about 111,000 miles on it and I don't believe the power steering has ever been flushed. Any help is greatly appreciated!
Old 07-23-2015
Prelude Owner
GolNat's Avatar
Re: Weird Noise Like a Remote Control Car
Could be the belt slipping. How do the serpentine belts look? There are 2. If the one is loose or cracked it could be slipping on the power steering pulley.
Quick way to check is to spray belt conditioner on it and see if the noise goes away.
Old 07-23-2015
mikey1's Avatar
is the noise consistant with the speed of the vehicle?
could be a bad wheel bearing
Old 07-23-2015
WWRCD?
(What would Ray Charles do?)
Old 07-26-2015
BootyDo's Avatar
Arrow Re: Weird Noise Like a Remote Control Car
Hey All,
So it looks like the fluid is at the min level. Looked full but after spraying the reservoir down with brake cleaner, it's easy to see. Picked up some belt dressing just in case though. Working from the easiest solution backwards, (topping off the fluid), does anyone know any reason I can't use this Prestone Honda fluid vs the
OEM Honda OEM Honda
steering fluid? I was thinking of doing a power steering flush - though it's not in Honda's maintenance schedule - and the price difference for 4 bottles or so is pretty significant.
Old 07-26-2015
mikey1's Avatar
belt dressing went out with the 80's
it is not recommended on todays modern serpentine belts,
there is no reason a serpentine belt should make noise unless its too loose
read......
http://www.daycoproducts.com/why-bel...t-a-noisy-belt
Old 07-26-2015
BootyDo's Avatar
read......
http://www.daycoproducts.com/why-bel...t-a-noisy-belt.
You sir, just saved me a belt!
Old 07-26-2015
Belt dressing just ruins belts. (Nice link, mikey1.)
If you think the noise is coming from the power steering, remove the belt and see if the noise is gone. At least that will prove if you are on the right track or not.
That's the left side. Left and right are always determined from sitting in the drivers seat.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
tylerginevan
04-27-2015 12:29 PM
carhag2000
04-25-2015 01:33 PM
Linda0818
04-23-2015 11:30 AM
SSMatey
04-13-2015 06:09 PM
Quick Reply: Weird Noise Like a Remote Control Car
