Replaced actuator... now auto locks after I turn on car and auto locks when turn off
Old Jun 29, 2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
I changed the actuator on the driver's side of my 02 coupe with an actuator I bought off ebay that is supposedly an OEM actuator. Anyway, it seems to work fine and my power locks work fine again with the key fob, but I noticed two things that are different from before the actuator failed a few weeks ago:
1. The doors now auto-lock after I put the engine in ACC or turn it on, about 1-2 seconds after. They also auto-unlock when the engine is turned off.
2. When the engine is on, I cannot use the internal lock switch (driver side) to unlock the doors. It does nothing unless I turn off the engine, and then (see #1 above) the doors auto-unlock. I can't really remember if this was the case before replacing the actuator.
Is this likely something wrong with the installation or something else problematic, or is there some other explanation?
Old Jun 29, 2015
Re: Replaced actuator... now auto locks after I turn on car and auto locks when turn
Get rid of the aftermarket (locks, alarm, whatever) unit. Dig under the dash, I'm sure it's in there somewhere.
Old Jun 30, 2015
h4ldol's Avatar
I do have an alarm but do you think that it would change how/when it arms/locks without having been re-configured/programmed? I noticed today that it is the key turning (to the second "stop", which is ACC I guess?) that locks the doors and turning the other way that unlocks the doors. I guess it's useful actually but mostly I wanted to make sure it wasn't a sign that there was something wrong with the installation.
Old Jun 30, 2015
CraigW's Avatar
^^^^ If you had the battery loose it may have defaulted its settings to what you have now.
An easy test would be locate alarm control and disconnect it, then try.
Old Jun 30, 2015
h4ldol's Avatar
Thanks, appreciate the input. I did disconnect the battery numerous times so that could be it. I will give it a try later.
Old Jun 30, 2015
^^What he said! LOL
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
cdt12271
Apr 23, 2015 11:36 AM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
dxb31847
Bolt-on Engine Performance
Nov 4, 2001 11:54 AM
