oil leakage - head gasket?
Old Apr 3, 2015
Amiri H's Avatar
Amiri H is an unknown quantity at this point
Unhappy oil leakage - head gasket?
Edit from moderators:
your issue have nothing to do with the previous thread you posted. moved to a new thread of your own.
hey everybody
just picked up a 2003 CIVIC 4DR sedan Stick
there is a bit of oil leakage near the head ( to the left side of engine and just going down on half the engine "
but
i have read through some forms and "head gasket symptoms"
Blown Head Gasket Symptoms:
Coolant leaking externally from bellow the exhaust manifold.
White smoke from the exhaust pipe.
Overheating engine.
Bubbles in the radiator or coolant overflow tank.
White milky oil.
Significant loss of coolant with no visible leaks
none of the symptoms are visible ,
im unsure guys, HELP please ??
and also if someone can give info regards to spark plugs and spark plug wires ,
which is best to use for tune up ??
Old Apr 3, 2015
Re: check engine light
Originally Posted by Amiri H
\ 2003 CIVIC 4DR sedan Stick
but
An oil leak will not be from a head gasket.
That's not saying it doesn't ALSO have a head gasket problem though.
There are no plug wires, and if you want to change the spark plugs I'd use what the factory put in there. NGK or DENSO.
Old Apr 3, 2015
Amiri H's Avatar
@ Ezone
That's a relief ,
otherwise would been a worst buy.
being in toronto
Canadian tire best place for me to shop
" http://www.canadiantire.ca/en/search...=list;x1=brand "
which of those would you recamond ?
Old Apr 3, 2015
Amiri H's Avatar
i mean that being something affordable
the first one is affordable since they come in 2's.
Old Apr 3, 2015
@ Ezone
That's a relief ,
Post pictures of your oil leak?
being in toronto
Link goes nowhere, I have no idea what you were trying to buy.
Search local parts stores online if you want spark plugs, but search specifically for the CORRECT plugs.
I'd hope most stores can get whatever you want overnight.... If nothing else, get them from a dealership.
The correct plugs should last at least 100,000 miles (160,000km)
My Honda parts catalog shows
DENSO PKJ20CR-M11
I'd also be ok with using
NGK PZFR6F-11
Old Apr 3, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Originally Posted by EManEX
^ Or you can go to Autozon or Kragen and have them check the code for free.
Not in California. Nobody reads them for free anymore.
Old Apr 4, 2015
Amiri H's Avatar
Re: oil leakage - head gasket?
Old Apr 4, 2015
^link fail, I got a blank page
Old Apr 4, 2015
Amiri H's Avatar
silly questions guys
how do i show u guys the pictures ?
here i cant just upload the picture
and u can see above a fail attempt of trying to upload a picture
another weird problem i noticed today is
when the clutch is released noise starts, and when clutch is pressed on the noise stops
Old Apr 4, 2015
Upload your pics to a pic hosting site like tinypic or imigur.
Copy the link to the image
Come back here and click the icon
Then paste/post the link into the popup box.
Old Apr 6, 2015
Amiri H's Avatar
hey every one ,
towed it to the shop , mechanic said the leak is from valve cover so no biggie there thank god,, but i do need a new clutch kit.
any recommendation where i can order online for cheaper ? as they charge like a beach if i ask them to order the part for me.
thanks ezone for the guide
Old Apr 6, 2015
Try Amazon.
What's the price they are quoting you?
Old Apr 6, 2015
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Make sure the shop is OK with you supplying the parts. Some shops will not install parts that you supply. Also, most shops will not provide any warranty on work if they don't do the whole job which includes sourcing the parts.
Old Apr 6, 2015
Amiri H's Avatar
@thesushiboy -
yea thats what im doing but just afraid of purchasing the wrong item.
if u could make any recommendation ?
i found this website , has it on sale for $84.63 ,
http://www.partsgeek.com/catalog/200...lutch_kit.html
if you guys can please check it and let me know ??
thanks !! ya 'all
@ PJB3 - yea mechanics either way nowadays dont care will just charge u either way.
Old Apr 6, 2015
Amiri H's Avatar
or this one ?
Amazon.com: EXEDY KHC08 OEM Replacement Clutch Kit: Automotive Amazon.com: EXEDY KHC08 OEM Replacement Clutch Kit: Automotive
Old Apr 6, 2015
@thesushiboy -
I go OEM on nearly everything that's essential or once in a lifetime replacement. Having said that, go here, put in your VIN and search for your exact part. Copy the part number into Amazon or Ebay or just do a google shopping trip. Good luck!
Old Apr 6, 2015
Amiri H's Avatar
@ thesushiboy -
thanks mate for the help.
where u able to take a look at the 2 site i had put on the board ?
would those be right fit
Old Apr 6, 2015
@ thesushiboy -
Np. That's what this board is for.
Yep.
Old Apr 6, 2015
Amiri H's Avatar
yea i looked at the amazon one ,
would the that be the idle kit i need for LX model ?
Old Apr 6, 2015
Amiri H's Avatar
just wanted to confirm before purchasing
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Tim1959
Jun 3, 2015 08:15 PM
Jun 2, 2015 11:54 AM
zaboomafoozarg
May 30, 2015 09:21 AM
HondaHomer
May 14, 2015 12:24 PM
