Behind the kickpanel??
Old Jan 1, 2015
ekm92's Avatar
ekm92 is an unknown quantity at this point
I'm chasing a water leak on the drivers side that has soaked the carpet. Behind the kickpanel up under the dash I found water running down in the very corner of the cabin. I also found a leak around the grommet of what looks like a drain tube but there's nothing connected to it. The tube is dry inside. The water comes in around the base of the grommet. Does anyone know what this tube is for?
ekm92
Old Jan 1, 2015
ekm92's Avatar
Re: Behind the kickpanel??
Wrong forum. Should be gen7 since its a 2003. I just can't figure out how to delete the post.
Moving to correct forum.
ekm92
Old Jan 1, 2015
ekm92's Avatar
2003 - behind kickpanel??
ekm92
Old Jan 1, 2015
ekm92's Avatar
Re: 2003 - behind kickpanel??
forgot to include the picture
Old Jan 1, 2015
mikey1's Avatar
check your rad/coolant level, is it low?
that leak could be coolant leaking from your heater core and/or connecting hoses
Old Jan 1, 2015
ekm92's Avatar
Shouldn't I smell antifreeze if it was that? I don't smell anything. The leak is coming in around a grommet behind the kickpanel. I'm trying to upload the picture but having trouble since I incorrectly posted this issues under the gen8 forum with the picture.
Old Jan 1, 2015
ekm92's Avatar
I think I figured it out. There was a hose pushed back into a hole that I didn't see. I tested the sunroof drain and it all poured out into the floor. I hooked it up to the black tube shown in the picture and tested the sunroof drain again. No water.
Old Jan 1, 2015
Sorry I wasn't around earlier. Merged the 2 threads so this may read kinda funny.
Yes, sunroof drain tubes sometimes pull out and leak. Secure it with a hose clamp if possible?
WhiteRabbit
84
Jan 19, 2015 11:32 PM
kachunkachunk
Dec 4, 2008 12:41 AM
MegaHurtz
Sep 16, 2006 01:17 PM
LudlamTheory
17
Jul 24, 2003 06:38 AM
WhiteRabbit
Mar 30, 2002 11:50 AM
