p0300 stumping this gearhead....
Completely stock 05civic ex se. Been trying to track down a p0300 (&0301,0302,0303,0304). Only does it as the car heats up to op. Temp. Every every path I test (ignition,fuel & air) come back inconclusive. The only thing that temporarily eliminates this misfire is chevron techron concentrate fuel system cleaner. I dont know enough (even with the month and a half of research) about this car to test voltages completely cause it seems to change everywhere I look.
Re: p0300 stumping this gearhead....
Post the freeze frame data and the code that it's related to, please
Valve adjustment?
EGR distribution plate passages clogged?
Valve adjustment?
I'll get get a freeze frame here soon. I wouldnt think valve adjustment cause when the cleaner is in it, it runs almost perfect. If I could describe it in a few words what its like, its as if the system forgets or loses when it needs to fire like its a few degrees off. Then it catches back up to where it needs to be. Until I slow down, then it forgets again when I accelerate.I havent gotten any lean codes, o2 codes, catalyst codes or anything other than 0300-0304. Btw compression is 183psi across all 4 cylinders.
Big bottle or small?
Ever seen how badly an engine runs when the tank has waaaay too much Techron in it? LOL
Civic720
Sep 10, 2015 10:06 AM
Ronin Nishimura
Jul 28, 2015 07:24 AM
Green02civic
Jul 27, 2015 10:48 PM
