coolant leak
Old Dec 10, 2014
denti's Avatar
denti is an unknown quantity at this point
coolant leak
Hi
so in the spring, i changed out the timing belt, tensioner and water pump and everything was great up until a few weeks ago
the heat would work intermittenatly and a few days ago, i noticed that i'm leaking coolant from the drivers side.
The car temp is within the normal range and is not over heating.
Looking around, i cannot find any hoses that would cause the leak from the drivers side and the only thing i can think of is that i'm leaking from the water pump.
Before i tear everything apart to get to the water pump, is there anything else you might suggest i look at?
thank you
Old Dec 10, 2014
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: coolant leak
Walk away from the parts cannon... Know anyone close that has a pressure tester? Diagnose it first. Sure would suck to put a pump on when all it needed was a clamp.
Old Dec 10, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: coolant leak
The timing belt and water pump change from this spring, was it a Honda OEM water pump?
Old Dec 10, 2014
Re: coolant leak
I'd suggest LOOK at the water pump before tearing it apart. You can see the weep holes from underneath with a flashlight.
Old Dec 10, 2014
denti's Avatar
Re: coolant leak
Thank you ezine. Didn't know you can see the weep holes from the bottom so that was the reason to take it all apart to see if I can see the source of the leak.
Thank you
Old Dec 10, 2014
Re: coolant leak
You may want a small mirror for better view, but they can be seen without teardown.
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
