Blown head gasket?
Old Oct 11, 2014
Metalzone's Avatar
Metalzone is an unknown quantity at this point
Blown head gasket?
So my car over heats.
Not the thermostat
Not the Fans/Cooling Fan switch
Not the water pump
Not the radiator
No leaks
Not the radiator cap
Whenever i fill up my radiator with coolant, and go for a drive, i need to refill it again because the coolant is gone? there are no leaks so idk what the problem is.
The engine oil shows NO signs of head gasket problem.
There is no white smoke coming out of the exhaust either.
Basically, the engine builds pressure and sends it to the radiator, and then into the reservoir.. which then overflows and spills everywhere!
Is it the head gasket?
I also did a dry compression test and my readings were:
Cyl1:125 Cyl2:130 Cyl3:130 Cyl4:140
(sorry for the grammar, I'm writing this in a hurry)
PLEASE somebody help
Old Oct 11, 2014
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: Blown head gasket?
Yes, it's your head gasket. Get it replaced ASAP. Reserve tank overflowing is the tell tale sign. Good luck.
Old Oct 11, 2014
see first post for testing methods.
https://www.civicforums.com/forums/3...reference.html
Old Oct 11, 2014
Sheirstles's Avatar
Sheirstles is an unknown quantity at this point
Did you clean the excess oil out of the impulse line, fuel pump, breather tube, air filter, and air cleaner? When the gasket blows, oil ends up everywhere usually.
Old Oct 11, 2014
Matt_75's Avatar
Not on this vehicle. Oil and coolant never mix on this engine when the head gasket is blown unless somebody completely destroys the engine.
Old Oct 12, 2014
mikey1's Avatar
yes.....
the combustion gases in the cylinder are getting pushed into the cooling system through the head gasket, this causes air to be in your cooling system, when this air is in the cooling system our coolant gets pushed into the overflow bottle,
Old Oct 12, 2014
Metalzone's Avatar
Thanks guys! Indeed it was the head gasket.
Hopefully this helps people who are encountering the same symptoms/issues.
I ended up buying a D17A engine with roughly 45k.
Old Oct 13, 2014
mikey1's Avatar
how can you be sure your "new" engine does not have the same issue?
if not, it probably will very soon, i hope you are getting a good warranty with it.....i think you would be better off fixing the one you have
Old Oct 13, 2014
Put a head gasket in this engine while it's out of the car. It's easier than doing it in the car IMO.
I've done plenty of these leaking head gaskets with very low miles.
Old Oct 13, 2014
Racechaser's Avatar
Racechaser is an unknown quantity at this point
I hate to piggyback threads but I rented compression tester (OEM BRAND I think) from Autozone, and the adapter needed a 13/16" socket to tighten adapter. Needless to say the socket wont fit in the spark plug tube.
Is there a tester you use that either the hose tightens and seals easier or the adaptercan be installed with a standard 5/8 spark plug socket.
I too have a blown headgasket I believe but want to verify it.
Old Oct 13, 2014
Baaahahaha!
Go back and see if they have the smaller size whip for the tester you got.
Or....buy a comp tester from Sears if you really need to do this test.
I rarely ever do a compression test, it doesn't net the results I need to see when trying to prove a blown head gasket on a 1.7 engine.
Compression will still be perfect even with a blown head gasket on most of these, unless it's been overheated so bad it warped the head.
Old Oct 13, 2014
Racechaser's Avatar
I have at LEAST 2 others that are buried in a box or loaned out to somebody so I hated to buy another one if I didn't have to.
It is good to know that it may not read very far off unless its really bad. I'm sure its blown but this was a learning opportunity for my 16 year old son whom I bought the car for.
I bought it knowing it likely had a blown HG, as the previous owner cited the symptoms. It ran hot, added water and started going again and later down the road his daughter said white smoke started coming out of tail pipe and then seconds later it quit running all together and wouldn't start.
When you say "shorter" whip, are you talking about the threads being 3-5 total vs. the 10 -15 of the longer version?
Thanks
Old Oct 13, 2014
Oooh. Ran overheated til it quit??? Now it can fill a cylinder with water? That's not good at all.
I might expect a warped head at the very least. Possible rings collapsed too. I didn't know it was this bad.
I meant one that will fit in your application since that 13/16" doesn't. One that has a 5/8" hex adapter, or just has the threaded end built in as part of the hose.
My Sears tester has the dual threads on the end of the hose, I have never needed to use the spark plug adapter that came with the kit.
I also have a Snap On compression tester kit too, it is my first choice at work.
Old Oct 13, 2014
Racechaser's Avatar
Yeah I bought a used engine from a reputable yard that has 75,000 miles on it that had been wrecked in the side.
Putting it in his car after I change belt and pump and I'm taking his engine out of the car and having head worked and looking at cylinder wear and replacing head gasket and timing set and then putting it in another civic I bought for me that had blown head gasket. LOL I'm a glutton for punishment but I figured it was good use of his motor. Plus as mentioned before it is much easier on a stand than in the car.
mistermenphis22
Apr 3, 2016 08:06 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
arokz89
Jun 18, 2015 08:25 PM
Jun 2, 2015 11:54 AM
HondaHomer
May 14, 2015 12:24 PM
