Clunk when turning left
Hi,
I have a honda civic 2003 dx 4dr and when I make a sharp left turn I hear one clunk. It doesn't clunk every turn, it doesn't do it when I turn right. The clunk seems that the clunk come from the right.
My mechanic was able to constantly reproduce the clunk by turning left in circle but didn't find the problem. He check all the bushing and everything look good.
I looked on internet and maybe it's the strut mount bearing but I'm not sure. I would like to have your opinion.
Thanks in advance. I will try to record a video with the sound and post it.
7th Gen Civic DIY Enthusiast!
Re: Clunk when turning left
I'd do another inspection and look closely at the lower control arm compliance bushings. It's the front bushing on the lower control arm. There's a chance it's torn and your mechanic missed it.
While you have it at the shop,, have them inspect the lower front engine mount as they tend to go as well. Easy to spot, check the webbing on the rubber mount for breaks. May not cause a specific noise while turning but will allow the motor to move excessively while under load.
Could be that a CV joint might be getting ready to die on you as well. I just had this issue were it would only make a clunk when turning right, after a CV joint change out all is well.
Matt, I'm guessing you aren't still in the service or you are close to retiring?
Thank you for the new idea to check.
Since there is multiple spot to check, is there a way I can check it myself or would I need some mechanical knowledge (which I don't really have...)?
oh yeah, you could jack up your front end and take a pry bar to do a wiggle test on everything. For the CV joints you'll want to look at the condition of the cv joint boots and then rotate it back and forth to see if it has a lot of play in it.
Dorval Andre
May 1, 2015 09:37 AM
GH04si
Apr 15, 2015 08:13 PM
Russps
Nov 8, 2001 02:00 AM
