2005 Civic LX Door Won't Lock/Unlock
Old Jul 18, 2014
Kennykenny's Avatar
Kennykenny is an unknown quantity at this point
I have a 4 door 2005 Honda Civic LX. The door lock on the passenger front won't lock/unlock using the FOB or the drivers side door lock button. It will only lock/unlock manually locking/unlocking by hand. The lock vibrates when using the fob and drivers side lock button but won't go up or down. Is this the lock actuator? Are there instructions on gaining access as well as detailed instructions on how to replace? Thanks!
Old Jul 18, 2014
mikey1's Avatar
Re: 2005 Civic LX Door Won't Lock/Unlock
remove the door panel, test for voltage at the lock actuator connector, and ground
Old Jul 18, 2014
tkcne's Avatar
tkcne is an unknown quantity at this point
If the actuator is bad this is how you do it: https://www.civicforums.com/forums/1...-actuator.html
Be careful with the three screws on the end of the door they are really easy to strip. (8th picture in the guide) I got a large #2 automotive screwdriver from lowes that worked great on the 2 that I didn't destroy. Ended up going to pull a part to replace the one I stripped.
Edit:
Didin't notice but that guide replaces the whole lock assembly. You can just replace the actuator which is the black part on the bottom and then reinstall the whole assembly.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
civic_gt
Apr 19, 2015 08:15 AM
dano2005
Apr 14, 2015 01:58 AM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
