REV Limit Issue
Old Apr 16, 2014
cburris's Avatar
cburris is an unknown quantity at this point
REV Limit Issue
For about a week now my car wont allow itself to rev over 3500 RPM'S.. Its like it has a Rev Limiter in it. I have changed plugs thinking it was just a foul plug with no success. It has actually turned completely off while driving about 55 shortly after the Rev issue. Not really sure what my next step should be. Any help would be appreciated.
Thanks
Also, This is a 2003 Civic LX
Old Apr 16, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: REV Limit Issue
CEL? Sounds like it's in limp mode. Oil level okay? This LX, is it an automatic?
Old Apr 16, 2014
cburris's Avatar
Re: REV Limit Issue
No CEL and Oil Level is good. It is a 5 speed. I do have a Malfunction indicator lamp on, but has been off and on for about a year. I think that is an emissions issue.
Thanks for the quick response.
Old Apr 16, 2014
mikey1's Avatar
Re: REV Limit Issue
check your timing/timing belt, you might have "jumped time"
could also be a cam or crank sensor
Old Apr 16, 2014
cburris's Avatar
Re: REV Limit Issue
I thought of that originally, but wouldn't it be much choppier of a ride. It doesnt seem to run bad while its running, just limits itself. Might be worth checking into though.
Old Apr 16, 2014
Re: REV Limit Issue
Originally Posted by cburris
No CEL
Those are 2 different names for the same idiot light.
Get the codes read. Get ALL the codes (by number not description) and freeze frame data if you can get it.
Go from there.
Old Apr 17, 2014
cburris's Avatar
Re: REV Limit Issue
Its actually in the shop now. Hopefully I get an answer today. Thanks for all the help!!
Old Apr 21, 2014
cburris's Avatar
Re: REV Limit Issue
It pulled a "Cam Shaft Position Correlation" Code. Im pretty sure thats what he said. I was driving and didn't have a chance to write the actualy code down. Any idea on that?
Old Apr 21, 2014
Poopies's Avatar
Super Moderator
Re: REV Limit Issue
So it WAS a timing thing! Here's a list for you! http://www.obd-codes.com/p0016
Old Apr 21, 2014
cburris's Avatar
Re: REV Limit Issue
My Man.. I appreciate that.
Old Apr 21, 2014
Re: REV Limit Issue
What was the actual code?
P0016 isn't possible from that PCM.
I'm thinking it would be more like P0335, P0336, P0340, or P0344.
Wraithen
Jun 7, 2015 01:48 PM
JoeB16
61
Oct 16, 2003 07:58 PM
CivicMonkey
Canada West
Feb 19, 2002 11:04 PM
Mokushi
Jan 24, 2002 02:55 PM
locozoko
Nov 8, 2001 06:33 PM
