Door lock please help
Old Apr 8, 2014
Brandino's Avatar
Brandino is an unknown quantity at this point
I have a problem with my door lock on the drivers side the power lock on that side does not work i think it's the acuator but I'm not complety sure
Old Apr 8, 2014
Re: Door lock please help
I can't tell what car you have here.....Is this on your Aston Martin, or the Jaguar?
Pull the door panel and find the connector for the power lock actuator.
Disconnect it.
Connect a test light bulb between the two wiring terminals for the actuator in the harness connector.
Operate the P/L switch (both directions), see if the bulb lights up each time.
If the bulb lights up, the system is ok and the actuator is bad.
If the bulb doesn't light up...... you have a problem.
Old Apr 9, 2014
CraigW's Avatar
Listen for noise from drivers door and watch lock **** for slight movement on 1st unlock press.
Old Apr 21, 2014
Javage's Avatar
Javage is an unknown quantity at this point
Disconnect it.
So I have a question;
The passenger side works properly, (but seems like its getting weak), the driver side only functions with the key from outside or manually push down the lock indicator and pull the handle from the inside.
I can hear the actuator "pop" when I hit the lock/unlock switch but it doesn't pull the lock mechanism, rod or lock indicator.
There are two connectors on the Left actuator/door latch, the bottom connector(2 wires) seems to control the power for the lock.
I don't have a Test Light, so how would I go about testing with a multimeter?
Old Apr 21, 2014
Poopies's Avatar
Super Moderator
So your driver's side actuator makes a noise but it can NEITHER lock or unlock the door?
Is it possible that your actuator is just disconnected from your lock mechanism? I haven't heard of that happening but it's possible I guess.
Can you feel ANY vibration in the door lock tab when you hit the lock buttons?
-If you can, then your actuator could be about dead. It's not THAT hard of a fix.
-If you can't, it might just need to be reconnected. That might be an easier fix.
Old Apr 21, 2014
Weak actuators are common....shortly before they quit completely.
If you can hear and feel an actuator trying to operate, then chances are good it's just a bad actuator. If there were wire or control problems, it wouldn't be able to work at all.
Sure you do.
Get any cheap #194 light bulb like this (pick one that works)
Straighten out the 2 wires at the bottom.
Presto!
Instant 12V test light bulb. Insert each leg into the 2 wire connector for the power door lock actuator.
Wanna get fancy? Connect lengths of wire to each leg of the bulb. Maybe use a real socket for the bulb.
Or use any 12v bulb you have handy, with a socket.
Or, you know, go spend $10 at AutoZone on a real one.
http://www.autozone.com/autozone/acc...er=186543_0_0_
Or $4 online
https://www.google.com/shopping/prod...d=0CI4BEPMCMAA
Or make one.
Old Apr 21, 2014
Javage's Avatar
Correct, I can hear it, but no movement. Everything seems to be connected.
Sure you do.
Presto!
Genius
I'm all about cheapies...but I will pick up a light next trip to Harbor Freight, I can't find my old one.
Old Apr 21, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
If you plan to troubleshoot your own electrical, there are few handier tools to have, than jumper wires. Two alligator clips crimped onto both ends of a length of wire, or two blade males or two blade females... you get the idea. This allows you to probe from the business end of a connector rather than pierce through insulation/weatherproofing to get to contacts... as well as better access via the extra length of wire.
I have a plastic silverware tray full of all sorts of combos, and they've been invaluable in fumigating electrical bugs, esp the intermittent kind. :P
Aladinbama
Aug 23, 2015 06:37 AM
viperGTS
Jul 27, 2015 08:40 PM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
