Passenger Door Lock doesn't work
Old Jul 30, 2015
Aladinbama's Avatar
Aladinbama is an unknown quantity at this point
Hey, new owner here
Anyway, my 03 EX passenger door lock doesn't operate with the key fob. It works manually (of course), but I'd like to get it operational again. My guess is there is a switch or circuit in the door that is messed up.
Where do I begin? Thanks!
Of course, if this isn't posted in the correct section, please feel free to move it!
Old Jul 30, 2015
mikey1's Avatar
Re: Passenger Door Lock doesn't work
does it operate when you use the automatic switch on the drivers side?
if no, i would start by removing the passenger side door panel and testing the voltage at the door lock actuator motor
Old Jul 30, 2015
Aladinbama's Avatar
Nope, it only works manually! My guess is that motor is toast!
Old Jul 30, 2015
mikey1's Avatar
that would be my guess at this point, however, a wiring issue is not out of the question, check the voltage at the motor
Old Jul 30, 2015
CraigW's Avatar
Best if you can determine if you have voltage reaching it.
Close the drivers door and work the power locks locked and unlocked several times and watch to see if the lock **** tries to move , or bumps even slightly.
Sit inside and listen close at drivers door during the 1st unlock press of the keyless (only drivers door unlocking) Movement or sound would indicate it is getting power to actuator.
Old Aug 19, 2015
seanywaa's Avatar
seanywaa is an unknown quantity at this point
Hey,
I'm having a similar issue with my passenger side rear door lock.
I have removed the actuator and tested it using loose wires across the battery - the actuator works.
Using a multimeter I'm not getting any voltage on the actuator wires (yellow/black/grey dot & yellow/grey dot wires).
I've also checked where the door card wires get back into the main body of the car and there doesn't seem to be any play or excessive movement in the wires so I'm assuming the wires are not knicked there.
Anyone with suggestions on what to try next?
I was looking for a wiring diagram online but can't find one as I was hoping to test the relay or controller...anyone know where the relay is located?
Thanks
Seany
Old Aug 19, 2015
This sounds like a wiring issue.
3 passenger doors are all wired the same (parallel).
I'd first guess a wire is broken in the boot between the door and body.
Old Aug 20, 2015
seanywaa's Avatar
I've checked with my hand by reaching into the rubber boot and it didn't feel like there could be a reason for a damaged wire...but I could check again.
Do you know where the wires are wired back to? If I knew that I could check continuity from start to finish.
Failing that I might have to rip out the interior plastic covers to expose the wiring.
I checked behind the glove box but didn't recognize anything associated with the power doors back there.
Old Aug 20, 2015
Is this a sedan or a coupe? Big difference.
When a wire breaks from flexing, it usually first breaks inside the insulation so it is not real visible but when you tug hard on it it will stretch then break the plastic. The wire will not stretch if it is intact.
This has been common on rear doors (sedans) with power window problems.
you might check power lock operation with the door halfway open and wide open, see if it works in some other position besides closed, that would indicate a broken wiring problem
You could unplug the wire harness from the body then ohm test from that plug to the lock motor connector (Sedan, rear door)
If this is a front lock problem I'd go to the fusebox instead.
Power locks are controlled by the MICU inside the drivers fusebox.
Pass front door is on plug "M" terminals 6 and 8,
rear doors are on plug "P" terminals 16 and 17
EDIT: If I looked up the right diagram...
Old Aug 20, 2015
mikey1's Avatar
i agree.....this happened to me
take that boot off and inspect the wires
Old Aug 20, 2015
seanywaa's Avatar
Thanks lads, some solid advice there...will give it a go over the weekend and see how it goes.
For reference my car is a 4-door sedan. But I hardly ever use the rear doors, which is why I wouldn't expect a broken wire there but the arguments put forward are very strong and checking the wires (checking the actuator at different door positions & tugging on them) will be my first step.
Then I'll get into the fuse box and go from there.
But as I'm leaning to a wiring issue now as all other doors work and it seems they originate from the same source.
Old Aug 22, 2015
seanywaa's Avatar
Hey lads,
Hands up who said it was a broken wire! Correct!! The wire was broken inside the wiring boot between the door and car body.
Thanks lads, ye are a wealth of knowledge, I don't normally post but I have used the forum for other issues in the past.
Cheers
Old Aug 22, 2015
Originally Posted by seanywaa
Hey lads,
*raises hand*
Do I win a prize?
Cheeseburger sounds good!
Old Aug 23, 2015
mikey1's Avatar
*raises hand*
Do I win a prize?
i guess i got second place, can i at least have some fries?
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
Ramen
Canada West
Nov 5, 2001 06:07 PM
