2004 civic SI Car does not heat up
Old Feb 27, 2014
vandiman3's Avatar
vandiman3 is an unknown quantity at this point
Hello,
I just bought this car last week and everything was fine. but now when i start the car it does not warm up. the temperature of the car after being on for about 10 minutes goes right under the middle between hot and cold, closer to the cold side. when i drive there is no hot air coming out of the vents it is cold air and the car does not warm up inside. i was told it may be my head gasket. can someone help me and tell me what i should do to fix this. thanks
Old Feb 27, 2014
Poopies's Avatar
Super Moderator
Re: 2004 civic SI Car does not heat up
How's you coolant level look? That can be a good way to gauge the health of your HG.
Old Feb 27, 2014
Canadian Si = USA EX. 1.7 engine.
My nickel bet says you bought yourself a car with a bad head gasket.
Old Feb 27, 2014
Word.
https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/340759-overheating-common-causes-reference.html
Old Mar 5, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Do read that post linked by ezone above... I turned on my heater full blast just on a whim to see what was going on (it was weaksauce)... and thought crap, I may have a HG problem. However, reading through that thread... just because your heater output is a bit weak, doesn't mean there's automatically a bad HG -- there are a lot of tests to do before you can narrow it down to nothing but.
Car is getting its front raised on jackstands and run cap-off, for starters -- car was sold to me with quite low -- but not out of the lines -- coolant in the overflow reservoir. Refilled, but probable needs a burp.
cooldan1
Apr 23, 2015 10:49 AM
chgofirefighter
Apr 18, 2015 08:08 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
TheRubixHorse
Apr 17, 2015 08:55 AM
GH04si
Apr 15, 2015 08:13 PM
