04 Civic DX auto trans issues... help plz
Old Nov 6, 2013
zkdawg's Avatar
zkdawg is an unknown quantity at this point
Question 04 Civic DX auto trans issues... help plz
my trans when full throttle will sit at highest rpm for a few secs before shifting. what could be the problem?
just recently it clunks when shifting in to reverse. i know its the gear and it seems like there is to much space between the mating surfaces and so it clunks.
i know the fluid is good as i had to do the pass. axle seal that was and still is leaking.
i bought a seal from honda this time instead of napa and will be replacing it here shortly.
the fluid is not low as i check it often from the leak.
the trans was replaced with a used one by the old owner.
it came out of a 05 per the VIN.
not sure how many miles are on it but the car has 142,xxx.
any help would be great.
Thx,
Zach
Old Nov 6, 2013
Re: 04 Civic DX auto trans issues... help plz
Go under the car.
Grab one inner CV joint and push/pull up and down in it while watching the opposite side.
Does the opposite side inner joint move?
Repeat check on the other inner joint.
It could be that time......
Old Nov 7, 2013
zkdawg's Avatar
Originally Posted by ezone
Go under the car.
i know they where replaced new when the trans was done and the noise is comming from the trans not the joint.
like i said its only with reverse gear.
thats not good
could it be the TCM(trans. control module)?
Old Nov 7, 2013
zkdawg's Avatar
i forgot to say that when not full throttle, it shifts fine.
no hard shifts, nothing.
maybe that will help.
Old Nov 7, 2013
At full wide open throttle, It's supposed to just reach redline (or damn close to it) before it shifts to the next gear......
but it's not supposed to hang there waiting for the shift, nor is it supposed to bounce off of the rev limiter while waiting for the shift to happen.
Does it do either of those?
Old Nov 7, 2013
zkdawg's Avatar
this thing doesnt have enough stuff to bounce,
but it does hang there.
Old Nov 7, 2013
but it does hand there.
(hand?)
Wait wait wait wait.......Engine has no *****? Can't bounce off of the rev limiter at wide open throttle???
Does it only do this on one of the shifts, or does it do it on all of the shifts? Which gears/shifts?
I'm wondering if this may not be a trans problem, could be clogged exhaust?
Can you measure exhaust backpressure?
Check Engine Light? Does it have any codes stored?
The clunk into reverse may or may not be good, I can't tell from here.
The axle seal leak, I was thinking that many of Hondas transmissions used to eat differential bearings, the carrier would become loose and you could shake it by pushing on an axle. Do replace the seal first and see what happens.
Old Nov 7, 2013
zkdawg's Avatar
it does on 1st and second gear but i cant get going to faster for 3rd+
so im not sure about the rest.
i didnt think of that, how common is it?
how could i check backpressure?
the only code i ever pull sometimes is P0497 but i erase it.
it comes back sometimes but takes a while to come back on.
i dont think its that, i jacked up the front end and when i turd the wheel back and forth u could hear it.
like the gears are just loud but it just recently started happening which is weird.
Old Nov 7, 2013
Yeah, this problem might not be in the trans.
Good enough, I didn't think many people would ever max out in 3rd.
Only as common as a clogged cat.
http://www.aa1car.com/library/exhaust_backpressure.htm
Read about the other symptoms that might get noticed too. Got any of those?
Google for more.
I would want to do the one that uses a pressure gauge screwed into the O2 sensor hole, then I'd really want to know what the backpressure is at wide open throttle and redline when it doesn't want to shift...
Where is the cat on your car?
If it is up in the manifold you can't do this, but if it were under the car you could open up one of the pipes between the engine and cat. Loud, but it would quickly answer the question of "is a clogged exhaust causing this?"
EVAP system low purge flow. Unrelated to the trans as far as I can tell at this point.
Not a good test. You're hearing free play between gear teeth in the differential when you do that. Every car on the road (with an "open" diff) can make that noise when you do it that way.
There are times and conditions where I totally expect to hear awful noises from these transmissions.
Almost all of Hondas trannys can make awful noises if the car isn't completely stopped when you change gears, or if the engine is idling real fast the trans can make more noise than usual.
Same if you are on a hill, there can be some noises when it pops out of park.
Motor mounts could let the engine move too far and bang, so can anything loose.
Exhaust heat shields? Loose bolts? Dropped wrenches?
Just thoughts....
HTH
Old Nov 8, 2013
zkdawg's Avatar
thx for the help, when i have time i will check it all out and get back.
thx again
usajags84
May 10, 2015 08:11 AM
C6GrandSport
Apr 25, 2015 09:41 PM
Myredjonda
Apr 14, 2015 07:00 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
