power window not working
Old Oct 25, 2013
touhey's Avatar
touhey is an unknown quantity at this point
Rear Driver windows doesn't move...others are fine.
I've been searching web on this issue for a few weeks....I've checked fuses, and some other routine checks. Today when i tried to put the windows up/down i get a click/knock sound and if i hold the switch and listen closely i hear a "sizzle". I don't recall hearing this previously, but perhaps i wasn't listening.
Anyway this occurs when using either switch. Does this ensure my switches are good. I would think, "yes". Does this ensure my wiring is solid, no broken grounds or leads. I would think "not necessarily."
Is the motor bad, what is sizzling ?
Old Oct 25, 2013
CraigW's Avatar
Re: power window not working
01-05 ??
Certainly sounds as if you are getting voltage to the motor.
The same one on my 05 failed (all the way up luckily) would not make a peep, but could see the dome flicker ever so slightly when attempting.
The motor is not available separate, but part of the regulator assy.
Old Oct 25, 2013
Pull back the rubber boot covering the harness in the rear door jamb. One of the big wires may have broken.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
got2kids
May 9, 2015 06:45 PM
ORskier
May 3, 2015 12:54 PM
