Oil Accumulation
Oil Accumulation
I'm about to put a dc sports ceramic header on my em2, i noticed i have oil accumulation between the block and the head, im not having any over heating issues, what is/ how do i fix this, im sure its simple, thanks in advanced
Re: Oil Accumulation
hard to tell but looks like valve cover gasket,
while you are doing your timing belt and have the valve cover off, i would suggest replacing the valve cover gasket, the camshaft end cap/seal (passenger end of cam), and the 4 seals around the spark plug holes, that should take care of all possibilities,
there is a cap that seals the passenger end of the camshaft, where the distributor would be if the car had one....its fairly common for that cap to develop a leak over long periods of time and, when it does oil will drip down and sit on top of the tranny, there are many threads on here about it,
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
