Car tinting ****ed up my defroster :(
Old Mar 23, 2013
azi90's Avatar
azi90 is an unknown quantity at this point
Unhappy Car tinting ****ed up my defroster :(
i just got done my tints on all windows 2 days ago and yesterday i noticed while running the defrost it only works on the half of the rear windows the other half stays frosted now i dont know if that guy is going to own up to it i think i need to replace the whole window now right ?
Old Mar 23, 2013
Re: Car tinting ****ed up my defroster :(
I bet you can't prove all the lines worked prior to the tint job. Good luck with that.
The top couple rows are NOT defogger lines, they are antenna lines.
You should be able to see they don't connect to the rest of the grid.
That said, if any of the lines are broken on the actual defog grid (it only takes a scratch to break the connection), you can repair them to a certain extent.
You have to be able to locate the actual break in each line, and they can be damn hard to see.
THEN you'd have to get the tint off without causing more damage.
http://www.familyhandyman.com/DIY-Pr...ogger/View-All
HTH
Old Mar 23, 2013
azi90's Avatar
HTH
Yeah i cant prove it im freaked out this alone if i plan to change whole window is going to cost me abt 5 bills ( I think) .. and i cant really tell my looking at it if there are any lines broken and yeah it is the top few lines thats not working,.
Old Mar 23, 2013
It would be prudent to look carefully before you waste a ton of money.
The top few lines are not part of the defogger grid.
Replacing the window cannot make them defog.
Old Mar 23, 2013
azi90's Avatar
So could it be wiring issue that he messed up ? may be not the lines.. ITS FROM TOP TO ALMOST MIDDLE that doesnt defrost.. rest is fine and i cant see any VISIBLE scrathes on the lining
Old Mar 23, 2013
DeamonG37S's Avatar
DeamonG37S is an unknown quantity at this point
nature will solve this one. Summer is around the corner
Old Mar 23, 2013
TO ALMOST MIDDLE
Ok, that sounds quite a bit different from "the top few lines".
Once the break in a line is located, it will be easier to see the breaks in the rest. Typically I find them all lined up in a row, more or less, from an action like washing the inside of the glass and scratching it with a ring or a watch.
But your guy just tinted it, IDK what might be a typical place to look in that case.
I'd use a voltmeter or a test light to find the break points.
Googled: http://autorepair.about.com/od/troub...snt-work_2.htm
Old Mar 23, 2013
azi90's Avatar
Not for the next winter..
Pir8pete
165
Mar 6, 2009 05:16 PM
sonsonzai
Nov 4, 2001 12:52 PM
wsking77
Aug 30, 2001 12:32 PM
EvoAdmin
Aug 28, 2001 12:07 AM
mj1010
Aug 26, 2001 09:52 PM
