Help needed
Old Mar 22, 2013
shanep1987's Avatar
shanep1987 is an unknown quantity at this point
Help needed
While changing the radio out on my girlfriends 2004 civic(hybrid) I managed to drop a socket somewhere behind/in front of the cup holder . I put everything back together, drove it and everything seems to be fine. I really don't want to take out the entire center console if everything will be fine for a little socket. I was just wondering if there is risk of something happening that can screw something up later on down the road? Also what exactly is beneath there?
Any help is appreciated guys.
Old Mar 23, 2013
mikey1's Avatar
Re: Help needed
it is very unlikely it will cause any harm....however if it was my car i would remove it....but thats just the way i am....
Old Mar 23, 2013
Re: Help needed
Like mikey, I'd take it out, but that's how I am, as well. That, and it takes me all of 5 minutes to remove my center console. It shouldn't do any harm.
Old Mar 23, 2013
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Re: Help needed
Did you try fishing it out with a magnet?
Old Mar 23, 2013
Re: Help needed
How about just buy another socket?
Old Mar 23, 2013
shanep1987's Avatar
Re: Help needed
I'm not worried about the socket, I just wanted to make sure there wasn't anything under there that could cause any issues.
Another quick question. She has the hybrid which has the CVT transmission. It has the super irritating "shudder" from initial take off. It only has 80,000 miles but is out of warranty, I dug around a little a seen that the only "true" fix is to rebuild the tranny and I'm damn sure not going to pay for that. Should she just turn the "economy" button off and sacrafice a few mpg, or should I make an attempt to flush the tranny on my own?
Old Mar 23, 2013
Re: Help needed
There were a lot of warranty extensions, product updates, recalls, and software updates on all those cars. Have you visited a Honda dealer about this yet?
Yes, you can DIY the fluid. If you can change the engine oil, you can do this.
Most of them SEEM to shudder. Most people put up with the annoyance rather than pay a lot to fix it.
Regular fluid changes seem to help, but don't eliminate it completely IMO.
Use the proper CVT fluid from a Honda dealer. It is not regular ATF.
And no "flushing", stay away from JizzyLubes.
Drain and fill only.
Multiple times if need be, but no machines or chemicals.
Read this bulletin, it gives a burnishing procedure to do first, then if that doesn't take care of the shudder THEN you do some real work......or ignore the shudder like everyone else. (BTW, you're probably well past the 7 year warranty extension on this.)
(PDF link) http://www.google.com/url?sa=t&rct=j...44158598,d.aWc
It's not really a complete rebuild, it would be replacing the start clutch assembly. The trans has to come out to do it though, so it's still a lot of work.
mattdoc
Mar 14, 2017 12:10 PM
usajags84
15
Aug 19, 2015 03:12 AM
Myredjonda
Apr 14, 2015 07:00 PM
jessepimpride
Nov 13, 2001 05:59 PM
