check engine light help
Old Jan 17, 2013
mislabeled's Avatar
mislabeled is an unknown quantity at this point
So I left for a bit and let my sister drive my 2001 honda covic ex while I was gone. When I come back I start my car and the check engine light is on. So I put it in drive and it makes a loud clonking noise. It sounds like the transmission. Also on the display when you put it in drive the "D" square doesn't light up and the tachometer will not go up. Any help would be nice because I know nothing about transmissions and I believe that's the problem.
Old Jan 17, 2013
Re: check engine light help
Start here. Post the actual code numbers and freeze frame data.
Old Jan 18, 2013
mislabeled's Avatar
I brought it to autozone to get the code checked out. They used 2 different scanners and they couldn't get a code to pop up
Old Jan 18, 2013
Has a timing belt or accessory belts been done sometime in the recent past? If someone left the alternator bolts loose, it can roast the PCM. No communication is only one of the possible symptoms.
Bad engine grounds can do the same thing.
Fire it up and check system charging voltage.
This is a guess, it is only a guess.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
