Squeaking noise when making a right turn
Old Dec 1, 2012
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
Everytime I take a right turn the left front side of my car makes kinda like a squeaking/squishy sound. I can clearly hear with my windows all the way up. I thought it was my strut mount and replaced that today but it still does the noise. Only happens when I'm making a sharp right turn. The sound comes from the left side only. Can it be a ball joint or even my front sway end link?
Old Dec 2, 2012
mikey1's Avatar
Re: Squeaking noise when making a right turn
sounds like your wheel bearing on the left side
Old Dec 2, 2012
Is there a way I can check if the wheel bearing is bad?
Old Dec 2, 2012
mikey1's Avatar
jack the car up so the wheel is off the ground, grab the tire with both hands and try to turn it left and right, and try to move it up and down, left and right, in and out, in every way possible....it should NOT MOVE AT ALL if the bearing is good....if there is any free play in any direction the bearing is shot
Old Dec 2, 2012
I checked wheel bearing this morning and did what you said by moving the wheel and well the wheel didnt move but the car shook left and right lol. So thank god its not the wheel bearing. One thing I noticed this morning was it happens over little bumps too like sewer tunnels. It also happens when im up halfway my driveway and I got a video of it.
I was just pushing the car from the front and it would make the noise.
http://s1120.beta.photobucket.com/us...O0015.mp4.html
Old Dec 2, 2012
mikey1's Avatar
ball joint or C/V joint
Old Dec 17, 2012
Matt300's Avatar
Matt300 is an unknown quantity at this point
Gonna second the C/V joint problem. Don't let this slide. I had a similar sound going on and decided I would wait a month if I could drive carefully and not push it on those turns. By the time I got to it, the problem compounded and I needed to replace a lot more than the C/V joint.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
edgenet
May 2, 2015 08:00 PM
SSMatey
Apr 13, 2015 06:09 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
