noise from driver's side under accelaration
Old Sep 20, 2012
mgslayer's Avatar
mgslayer is an unknown quantity at this point
I have a 2002 4 door 5-speed Civic EX with approx 120K. I had a noise from the drivers side from that you would hear/feel when accelerating, almost like a popping. Since the noise started I have replaced the following: driver's side engine mount, front engine mount (ripped to shreds) both complete front strut assembelies (springs, struts, etc). lower control arms because rubbers were shot, outer tie rod ends, front and rear sway bar control end links and bushings, and had the front end aligned. Car is alot tighter but the noise is still there. Checked the lower ball joints by jacking up and moving the tire and trying to pry up with a pry bar and no noticible movement.
Any suggestions?
Thanks
Mark
Old Sep 21, 2012
mikey1's Avatar
Re: noise from driver's side under accelaration
you seem to be ignoring the engine itself, maybe its something in the timing area causing it, tensioner or water pump? it could also be your A/C compressor
Old Sep 21, 2012
mgslayer's Avatar
Since the noise started I did also repalce the timing belt, tensioner, etc due to a leaking seal oil seal that the dealer did not do or even recommend. Even though it only had about 30K on them since the dealer did it, figured while I was in there might as well replace the tensioner, (which the dealer did not do). Only thing I didn't do was the water pump. After replaceing everything the noise was still there.
Thanks for the suggestion though. I've been playing with cars for almost 30 yrs and I'm stumped. I know it's going to be something simple.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Poopies
Apr 20, 2017 11:36 PM
pratik05
May 15, 2015 01:54 PM
civicns
May 8, 2015 09:49 PM
johnnieblazze
Dec 6, 2001 03:07 PM
