Trunk brake Light Out?
Old Feb 2, 2012
Rhonlynn's Avatar
Rhonlynn is an unknown quantity at this point
Unhappy Trunk brake Light Out?
I have a 2004 Honda Civic EX. My right trunk brake light is out,and I read int he book that you turn the socket a 1/4 turn counterclockwise, and change the bulb, replace the socket. I've changed the tail light bulb, but never a trunk light bulb. I know I can do this, but the socket isn't turning for me. Is this something I can change myself?
I'm soon to go out of town with my job, and this came up. I didn't want to spend $200 to change my trunk light, when I'm sure I can do it myself. Thanks!
--Rhonda
Old Feb 2, 2012
Re: Trunk brake Light Out?
Pliers?
Old Feb 2, 2012
toucansam333's Avatar
toucansam333 is an unknown quantity at this point
Ezone is right pliers for sure.. Had the same problem with a side marker on the tail light cluster; could not get it for the life of me. Pull that lining out of your way and get a set of pliers not needle nose ones and make sure you don't squeeze hard or you will be replacing the socket as well. If you need a rag or even those rubber grips for opening metal tops on glass jars; something to wrap around the plastic to give yourself more grip can help.
Old Feb 3, 2012
CraigW's Avatar
Good seal.
Poopies
Apr 20, 2017 11:36 PM
MamaBear2015
May 27, 2015 12:04 PM
Optimus34
May 25, 2015 11:52 PM
Ma213802
May 18, 2015 07:01 AM
wawacito
Nov 5, 2001 03:32 PM
