Wreck of a mess
Old Aug 28, 2011
sdaugh7261's Avatar
sdaugh7261 is an unknown quantity at this point
Wreck of a mess
Okay I have a 2001 Honda Civic LX 4-door
it has 20600 miles with 1 engine swap (1st engine blew a piston threw the block)
New (used) engine has 86k miles on it allegedly
I have put on the ebay special CAI (ram air setup, cold air made vehicle hydro-lock in rain)
Also, the cat has been gutted...didn't have 400 for a new cat.
so I get 24mpg city.....somehow this doesn't seem right to me....ideas? or is this because i'm using a metal air intake that gets very hot, and because my cat is gutted causing a CEL
alsooooo, i'm a delivery driver so i need to get there fast and tend to drive my car all day long.. so should I stick the factory air intake back on there till I can afford a composite CIA? also would a transmission cooler be a good idea for vehicle life......
Old Aug 28, 2011
Re: Wreck of a mess
have you done the normal tune-up items, as well as cleaning the sensors and such?
Old Aug 28, 2011
sdaugh7261's Avatar
Re: Wreck of a mess
Yes sir
Old Aug 28, 2011
Re: Wreck of a mess
how long ago?
Drving style? remember that when coasting in gear, if you take foot off the throttle the fuel cuts until you step on the gas again. feathering pedal helps tons too. (no excess step;ping, just what you need).
did you feel a drop after the intake install? If not, then no point in changing intake.
if yes, is the sensor well plugged? no vacuum leaks?
Old Aug 28, 2011
sdaugh7261's Avatar
Re: Wreck of a mess
well I noticed that i got about 38 highway which to me is good, but the metal pipe itself gets very hot threw-out the day and i'm wondering if that is causing it to lose mpg from hot intake.
Old Aug 28, 2011
Re: Wreck of a mess
i get 42 hwy, but you miss the point...
Old Aug 28, 2011
sdaugh7261's Avatar
Re: Wreck of a mess
well, I switched back to the old intake that's plastic, and see how that run's and then I will go from there.
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
Dsmak
Sep 10, 2015 08:30 PM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 12:30 PM
