Subframe torque specs? Not in my haynes
Old Aug 12, 2011
Hardcoresteve's Avatar
Hardcoresteve is an unknown quantity at this point
Does anyone have the specs for the main subframe bolts? I checked n its not in the haynes manual. Says chapter 10 but its deff not there. Ive also checked the forums n all I found was specs for struts and other suspension parts...its an 05 civic vp em2
Old Aug 12, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: Subframe torque specs? Not in my haynes
Tight I know that's not the answer you are looking for though...
I bet 99.9% of guys that have them off hit em with an impact to tighten them. When you are working flat rate time is money. They can't be that much anyway... It would probably suprise you. They aren't big bolts. I would be suprised if the spec is more than like 120 ftlbs. If you have a long ratchet tighten them up as tight as you can and that should be ok....
Old Aug 12, 2011
Haha ya true, but im **** with my own car. When im in the shop its different lol. I contacted haynes and within 5 minutes got an email response. Strange that they forgot it in the manual?!? But its 78ft lbs for main bolts, and 47ft lbs for the smaller two. (i went to 80 anyway)
Old Aug 12, 2011
lazlong's Avatar
Not exactly right but, close:
Tedverseti
Apr 23, 2020 01:45 PM
cferry7
Oct 18, 2015 06:32 PM
Islesfan
Sep 29, 2015 03:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
Elciteeve
Sep 28, 2015 12:40 PM
