Whole lotta shakin going on...
Old May 28, 2011
kateslittlecivi's Avatar
kateslittlecivi is an unknown quantity at this point
My 01' Civic has some issues in the front end. When in 5th gear going over 50 mph the car will begin to shake (left to right) almost as if the right passenger side tire were wobbling. When braking at speeds of 40 mph or more the car will also do the shaking/wobbling but the braking will be rhythmic (again as if the tire itself is wobbling). The pads are about 4 months old. The rotors are original and the entire front end suspension was replaced by Honda about 3 years ago. I am trying to get an idea of what the issue is. The car has 230k on it and generally runs well but is starting to show its wear mechanically. It seems it is burning oil as well and the trouble code P0420 comes up when scanned. I haven't replaced the ob2 sensor or the cat, but the engine seems to run fine. Anyone have some imput as to what may resolve the shaking up front?
Old May 28, 2011
lazlong's Avatar
Re: Whole lotta shakin going on...
For the P0420 you need to replace the catalytic converter if you've already replaced the sensor(s).
For the shaking: Lift the front of the vehicle and shake the wheel in and out. Top and bottom movement is a bad wheel bearing and front and rear movement is a bad tie-rod.
Old Jun 4, 2011
performanccivic's Avatar
performanccivic is an unknown quantity at this point
Sounds like your wheels could be out of balance, especially if this happens at higher speeds.
usajags84
15
Aug 19, 2015 03:12 AM
kevin99ek
Apr 23, 2015 09:32 PM
Grey
North East
Apr 7, 2003 06:53 PM
CuRiOuSfIsH
Mar 5, 2003 10:01 PM
Cyko
Feb 21, 2003 01:47 PM
