Loud thump when I hit a bump...
Old May 9, 2011
Smythley's Avatar
Smythley is an unknown quantity at this point
I've got a 2002 Civic EX sedan. 175,000+ miles. Replaced a strut with the help of a DIY on civicforums. After a couple months, whenever I hit a bump on the driver's side, it makes a pretty good thump. It sounds like it's coming from the front driver's side in the suspension. Any guesses? It's similiar to the sound that having a bad shock made.
Old May 9, 2011
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Re: Loud thump when I hit a bump...
Is the thump from the same side as the replaced strut?
Old May 9, 2011
Smythley's Avatar
Yes it is. Sorry for not making that clear.
Old May 9, 2011
lazlong's Avatar
Did you change the top mount bearing (always recommended when changing struts)? Is the spring seated right? Do a suspension inspection, if you can DIY struts then you should know what to look for.
Old May 10, 2011
Smythley's Avatar
I did not change the mount...
I checked out the whole front suspension and can't find any play anywhere, which leads me to believe it is the strut mount...
Correct me if I'm wrong, but I don't think I will be able to tell if I have play in the mount until I compress the spring. Otherwise it just stays tight, right?
So it looks like I'll be pulling strut and installing mount. Any helpful tips? Other than "replace the mount when you replace the strut the first time"...I feel pretty dumb not doing it when it was out. I looked at the mount and it didn;t appear to have play in it when the strut was out of it. I won't make that mistake again.
Old May 10, 2011
lazlong's Avatar
Eh, don't worry about it. I've done the exact same thing. lol
Old May 10, 2011
BlueEM2's Avatar
Whachya lookin at?
They probably werent indexed properly
Old May 10, 2011
Smythley's Avatar
You saying the strut and mount weren't indexed correctly? How do I avoid this when installing the new mount?
Old May 10, 2011
BlueEM2's Avatar
Whachya lookin at?
Make sure the arrows on top line up
Old May 10, 2011
Smythley's Avatar
On the mount or the strut?
Old May 10, 2011
BlueEM2's Avatar
Whachya lookin at?
Mmmmm.. instead of explaning I'll get someone else to show you
https://www.civicforums.com/forums/4...like-pics.html
Hope that helps.
Old May 11, 2011
Smythley's Avatar
Thanks. I made sure the top was lined up , but not sure about the bottom. Tearing into it tonight...
mgrantaz
General
May 2, 2022 05:40 PM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
MichaelLW
Sep 14, 2015 07:15 AM
yyyktk1
Sep 12, 2015 04:02 PM
